Oil change mess
Sure it's slower, but you're not going to get hot oil spewing out of the drain, so you can drain the oil when it is at full operating temperature without burning yourself or coating your tools with hot oil. Saves a whole lot of mess too because you can just stuff the hose in your drain pan, open the valve, and take a break while it drains. Or you can do the filter while it is draining because you can move your pan to sit directly under the filter because the hose is making sure you don't make a mess.
Seriously, if you haven't used one of these, you have no idea what you are missing.
I actually back the F into my garage and set the ramps on the driveway so when I am on the ramps the car is pretty much level.
Tech Info Resource
I haven't tried removing the valve after draining to see what the exact volume is. If you are really worried about it, you can add a second washer, or if you're really wound up about it, you can drop the pan and grind it off flush with the inside of the pan. It's impossible to get all the oil out of an engine which is why there is a dry fill number and a change number. Dry fill is usually about a quart more than change in an engine our size.
1) you need a special "socket" to attach the drain hose to the shorter nipple. The socket was $1.00.
2) There was no cap available for the shorter nipple (to keep dirt out etc). You could probably just get the cap for the longer nipple and cut it down.
I never though I would use the word "nipple" so many time is a paragraph.
-R
Fumoto F-103N is what you need for this one and most Scion/Toyota/Lexus engines. I just stick a clear plastic hose on the nipple, open the valve, have a beer or two while I'm waiting, then close the valve and it's all done. No mess, no fuss. The worst part of the oil change now is the filter change.
Tech Info Resource
Still works a charm. I put one in my Supra and I found it stuck in a bit far and left a little over a quart when level and fully drained using water. I did some custom grinding on it an got it down to less than a cup. I imagine I could do the same with the GS F and IS F, but with 10+ quarts at full capacity vs. 6.6 for the Supra, it makes a much smaller difference. The burr bit wasn't my best friend, but I'm not worried about it since this spot is constantly covered with oil, so corrosion is very unlikely.
The following 3 users liked this post by lobuxracer:
The following 2 users liked this post by dosnglenn:
21ce (12-06-23),
lobuxracer (12-05-23)
