Spec for fuel trim and MAF readings at idle
Potential issues stemming from RR Airbox and tune. CEL P0101
Does anyone have the specifications for long and short trim fuel at idle and under load, as well as what the range (g/sec) is for the MAF sensor?
I am fighting P0101 and deductive logic has taken me as far as I can go. I have checked for vacuum leaks, a bad connection on the MAF harness, and switched to a new Denso MAF sensor. No luck... It is still choppy in the lower rpms. I have not seen anyone say in similar circumstances that it is o2 related, but I am beginning to wonder if it could be.
UPDATE: Solution found on page 2
Let me just say that Simon and Rafi have been great in helping me through this issue. They have picked up the phone, emailed over the holiday weekend, and offered sound advice for troubleshooting. Thanks gentlemen!
UPDATE 2: The problem persists despite the new MAF pipe. Fuel trims are showing a lean mixture. The car runs fine with the stock box and RR tune, but all hell breaks loose with the RR tuned intake and a couple of different maps for the intake.
Nick, I've been having the same issue with the rr tuned intake. About every 50 miles i would get a CEL which would always include P0101 and a P1170 every so often also. After a month of trying to track down what could be causing it (including a new maf), I finally reverted back to the stock airbox and regular tune. Absolutely no issues to report for the past 200miles so far. I still have to email rr about this issue since I'm a little upset that I have a $650 part I can no longer use.
I get a code within 20 miles of driving after clearing the code and resetting the ECU. It has never cleared itself. I do not have an AOS, so the lines going to the PCV have not come off.
Auto Detailing Master
I think the next logical step is to put the car back to the way it was before codes... so remove tune and remove RR air box.
You're welcome to remove and borrow the O2 conditioner from my car for a few hours to get the feedback you need to help determine if the issue is correlated to the RR mods or not.
nicklausw- make sure the AOS hoses are pushed all the way in to the fittings. Also check that the reservoir cap is tight. I had this happen to me - not an RR issue I had accidentally knocked a hose loose doing other work.
I don't have the AOS, so that eliminates all those leaks on the PCV vacuum lines. I have also thoroughly gone over the vacuum lines and have not come across anything that changes idle. There is a tech at the dealer that is aware of my mods and issues. I am hoping to have him take a look soon.
