Isf first gear jerk
Isf first gear jerk
Hi guys. Recently I noticed that upon cold start driving in auto, when shifting out of first gear the car jerks forward a little bit. This does not happen when the car is warmed up, anyone know what this issue may be or if its something normal?
Like everyone mentioned above with the addition of common symptoms of being low on transmission oil. You should start digging some of those threads and make the best possible evaluation. From what I read, it isn't too expensive. Rather, the procedure is more critical in order to successfully get rid of those symptoms. Good luck!
My first gear is a jerk too Wantedisf! Why just last week I caught it smoking the rear tires. I'm like dude; you're going to get me in trouble! I mean, really, jerk! I'm just using second for now on! First definitely has issues!
Tech Info Resource
Fluid level is low. These gearboxes are very sensitive to fluid level and it drops over time even if it doesn't leak.
Tech Info Resource
xcamryman
08-18-06 11:24 AM
