Upgraded to the Two Piece
So my Stoptech Drilled were shot after all my track days this year. They had the spider cracks but hadn't spread to the outer ring yet but close. So I went and pulled the trigger on the Figs/RB Two Piece fully floating set up. They are lighter then stock so help with unsprung weight, cooling and should stop better too. Now I cant wait for next spring to get back to the track.
Stay tuned.
Stay tuned.
Looks great, I'm loving mine.
What pads are you running with these rotors btw?
Brake Pad Options: RB XT910 Street/ Mild Track
Front Rotor
355x32mm
Weight Comparison (per rotor)
One-piece 27.5 lbs.
Two-piece 20.5 lbs.
Weight Savings: 7.0 lbs.
Rear Rotor
340x28
One-piece 22.0 lbs.
Two-piece 17.5 lbs.
Weight Savings: 4.5 lbs
Front Rotor
355x32mm
One-piece 27.5 lbs.
Two-piece 20.5 lbs.
Rear Rotor
340x28
One-piece 22.0 lbs.
Two-piece 17.5 lbs.
Nice man! I'm still beating on OEM rotors, so cheap that I can go through them like socks
