Bad hub/wheel bearings?
Tech Info Resource
The skipping sound is from the rear LCA bushing. Replace it with a polyurethane bushing or a solid bushing and all this will end. AMHIK.
Tech Info Resource
I had all kinds of pops from the front end with the OEM bushings. Especially backing up at low speeds in parking lots with a high steering angle. It stopped when I put FIGS polyurethane bushings on the front LCAs.
On a side note, my JoeZ exhaust just got really loud all of the sudden and it has been on for a year now as well. I gotta get under it and see if a gasket let go.
So no one has experienced my wheel of fortune noise coming from the front?
Originally Posted by ZDCATC
Heres a diagram of an 08 wheel hub. We would use the 51 ftlb (or 51ftlb x 12 = 612 inlb) number since we're using a normal torque wrench not an SST. Can someone with an updated service manual confirm this? And is it the same for all model years?
Attachment 404685
Hey guys... I've been putting off a plethora of front end work (swap in new rings on 2-piece rotors, new adjustable UCA's, missing hub spacers, install re-built Penskes, replace a bent tie rod, etc), and now there's a squeaking noise coming from the front-left wheel. It sounds just like a hamster wheel up until ~10mph, where it goes away. I haven't read anywhere that squeaking is a symptom of a bad hub. The brake pads are fairly new.
I'm not sure what else it could be and wanted to check in before I get the front end apart and realize I need different parts.
Also, anyone care to update their experiences with the Autozone hubs? They're running another 20% off sale, so I'm tempted to just buy them, and if the noise is something else, they'd be easy to return...
Thanks!
Thanks!
Tech Info Resource
Thanks!
Thanks!
