Miro 111 non hub-centric.. Help
Installed my lexus centercap stickers shipped from china today.. Perfect fit but i noticed rim is not hubcentric.. Worried the stress it has on the studs.. Is there an aftermarket adapter you guys use for your non-hubcentric rim.. I asked miro and was told they were hubcentric.. Pics of centercap on miro 111..
Most aftermarket rims are not hub centric as they're massed produced for all cars. They usually come as 72mm and our cars require 60.1mm. You can find these hub centric rings online; they come in plastic or aluminum usually.
There are threads on this. Use the search function.
Here's a couple:
https://www.clublexus.com/forums/is-...re-set-up.html
https://www.clublexus.com/forums/is-...ing-lc818.html
Lou
Here's a couple:
Lou
Tech Info Resource
Nice looking wheels. Did you happen to weigh them before mounting the tires? Would love to know if they are also lightweight.
The material is unimportant. If the wheel moves against the brake disc, you failed to properly torque the wheel lugs. If it moves with properly torqued lugs, you have a much bigger issue and need to get better wheels.
i have same wheels
19 x 9.5 weights 22.5 lbs
Glad I found this thread. Just ordered a set for my Volk ZE40's. I'm experiencing some minor vibration from the wheels and I think this will be the fix for them. The wheels were road force balanced when tires were put on and alignment was performed shortly after so it's definitely not those two!
