Performance Mod Ideas please
My 09 has the Joe Z which I will leave for now, and Takeda intake. I dont want to do headers, so looking for mod ideas?
Your #1 Lexus Vendor
RR-Racing.. PM me and I'll give you pricing..
Check out RR-Racing.com or Meraki-Autoworks.com
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
Just gathering info that has been shown on the forums, FBO (headers, exhaust, intake, and tune) will typically yield anywhere from 420-430 WHP. That is pretty substantial, and outside of the tune, was unheard of for this community just a few short years ago.
If you're not looking into headers, the next best approach is subtracting weight on the vehicle, in particular rotational mass. Two-piece rotors, lightweight wheels, and even wider tires can produce a brand new feel in the driver's seat. When I swapped the OEM rotors for the two-piece ones, I saved about 24 lbs. I weighted my wheels and tires compared to the OEM setup and lost about 5 pounds per corner there, too. It has undoubtedly resulted in quicker acceleration and a better driving experience.
Here's an idea below with this link, there are many threads on this mod but this is one of them and I'm leaning towards getting it as well
https://www.clublexus.com/forums/is-...love-it-d.html
f sport rear sway bar
figs spherical bearing rear end rods
big brake kit 2 piece rotors
coil overs Penske or Ohlins
wheels if smaller than 8.5x 19 front 9.5 x19 rear
Tires 255 35 19 front 275 30 19 rear ( you can run this rear with fender roll in the back)
handling just as important as power mods
lca solution rr USRS or figs lca bushing
others have claimed that they run the same tire combo on different (DK if stock or aftermarket) wheels with no rubbing and no fender roll required.
my personal advice, get a PROFESSIONAL, who knows what they are doing and uses a heat gun so the metal doesn't crack.
i had mine done that way, FLAWLESS workmanship can't even tell and was less than $150 bucks. WELL WORTH IT.
i would encourage people not to fear the possibility of a feder roll, as long as you have a professional doing the work.
do your research the best you can, get what you want THAT YOU THINK WILL REASONABLY FIT, and get a roll job done if needed.
i know there are guys with really agressive fitment ( one guy running 305 rears) and that's cool, but is a lot of work with fender roll lowering and agessive camber adjustment.
IMHO ( shared by rr racing btw, respect those guys and FIGS ALOT) 275 is sweet spot on the rears, doable with minor adjustments which may or may not require a roll ( depending on rim size and offset , don't forget about offset). Higher than that and you are gonna need some serious work (lowering camber, etc)
https://www.clublexus.com/forums/is-...ml#post9572866
-Mike
What about some how converting out water pump to an electric one to help some of the power lost through the accessories, maybe an under drive crank pulley , maybe an RCF intake manifold and TB / combine with a RR tuned intake, most of these are waayyyy out there , but now we have a tune and start looking at other stuff to gain HP here and there . what's everyone's thoughts?
OP, is your exhaust catback? or just rear section? I'd suggest going the route of having a true dual setup.
lower rear control arm
traction arm
upper control arm
camber arm
toe arm
looks like this installed
http://shopfigs.com/v3/index.php?rou...product_id=207
http://shopfigs.com/v3/index.php?rou...&product_id=55
http://shopfigs.com/v3/index.php?rou...product_id=179
http://shopfigs.com/v3/index.php?rou...&product_id=81
there are five arm replacements they offer. You will find them listed by function
traction arm
upper control arm
camber arm
toe arm
