Coolant leak and new O rings
Hi all
at first sorry for my english, hopefully you will understand.I've got same problem like in this thread..
https://www.clublexus.com/forums/is-...-of-engine.htm
So I brought my ISF to the car service (not Lexus or Toyota) During repair repairman destroyed 2 Injection. So I needed order 2 new one. But here in Europe is this kind of injectors so expensive(1100US a pcs.). So I found solution make an order from China. There is the item really cheap.
I made the order for Original TOYOTA Fuel injector / nozzle 23250-31030 /23209-31030. after couple days I got the injectors. But the injectors came without 2 whitte O ring seals. So I ordered the Toyota genuine O rings. But right now I figured out is probably impossible put the one of this O rings on it. I called to Toyota service and even they don't know how do it or don't say true...
Is somebody here , who knows how put the the O ring seal on injector? I would point out I have problem just with one of two O rings. More specifically with the one that is closer to the center of the injector
any help will be appreciated
tresmith00
NX - 1st Gen (2015-2021)
14
11-25-15 12:40 PM
