Vsc light, traction, and cel
Did some searching but haven't found anyone with my error.
Car goes into limp mode with vsc, traction, and cel only when i wot 1st gear and on sports mode, 2bars on the transmission oil temp.
No weird startup, and drives fine regularly.
What can cause this?
Yea, i plan on getting the codes pulled.
lights turn off once i restart the car. And once the car is warmed up, I can do multiple wot launches without any problems.
May I ask why you installed an o2 simulator without a header?
When you start your car up, can you still start from 1st gear now?
When I didn't have the o2 simulator installed, I was not able to start from 1st gear in manual.
with my exhaust I occasionally get this. Bought a blue tooth OBDII reader and use it with dash command for iOS .
usually triggers when certain environmental conditions occur but no real rhyme or reason to it. I check the code and usually just reset the it. Clears the cel and the vac and trac lights. Just be careful if you are doing spirited driving when a cel occurs. I didn't know at the time about it automatically deactivating trac and esc almost ended up in a ditch.
iterval has been between 500 and 2500 miles between occurances. Had the car checked and nothing wrong each time. If it's a different code you probabally need to have it looked at to investigate further.
Once i pull codes, things will make more sense. Hopefully
