Speed Attack Stage III Rotors
Has anyone heard of or used these? Was looking for a quality rotor for potential track days at Road America and wanted to avoid drilled for the track. Any input is appreciated.
http://www.buybrakes.com/p-1108-spee...ed-rotors.aspx
I'm not sure, never heard of them. Frankly I'm very happy with the OEM ones, they're cheap and I trust Brembo more than Speed Attack, looking at the price, I would not trust these rotors or take track abuse, if your OEM are still good, I'm sure they're a lot better than those.
http://www.ebay.com/itm/Lexus-IS-F-0...9XOriG&vxp=mtr
Keep in mind, our cars are track ready out of the box, so upgrading parts on it with cheaper ones, does not mean better. I drove ISF on the track for many track events the way it rolls off dealer floor and after many years of track days with different cars, I never took it easy on the ISF either, not a single problem, brakes not fading, first upgrade I made was better tires
Looks like they're associated with Hawk Brakes. From the description, I would not have a problem using them. And Yes, I agree with you on using slotted rather than drilled rotors. Lexus is now using slotted rotors on the RCF and GSF.
http://hawkbrakesdirect.com/c-79-brake-rotors.aspx
Lou
Lou
looks like a great slotted option. I have met so many F'ers from Australia and New Zeland on my Facebook page and they have mentioned some other slotted options that seem great too. Id like to ditch my drilled rotors because its a pain poking out all the clogged holes after a track day
This does seem like a very good and budget friendly option for slotted or solid rotors. I wouldn't be worried about using them. Coming form Hawk direct they are probably acceptable. I'm not to much of a rotor snob, they are metal, pretty simple and the science behind metallurgy has been around for a long time. Most of the steel is purchased and manufactured in China anyways for almost 98% of the industry no matter what you hear. You ain't buying no high grade P20 mold steel from the US these days. If the post process is done in the US then it should def be fine.
We start with blank StopTech or Centric Rotor Cores
Correct and tested G3000 Rotor Metallurgy
Precision drill and/or slot machining in California
Meticulous surface finishing and mill balanced to eliminate vibrations
Precision OE vane and casting designs
Zinc coating for added protection against rust and salt spray
Speed Attack Rotor friction surfaces are double disc ground for more effective pad-rotor break in
Speed Attack Rotors– Unparalleled combination of value, quality and performance.
Non-Directional Finishes.
Machined non-friction surfaces.
1 year on warping, one year on manufacturer defects such as cracking (rotor must be within the minimum thickness).
mindcrime
03-31-17 06:43 PM
MK4Sup_isF
14
07-31-14 08:43 AM
melbitoast
03-29-12 05:46 PM
Spooled
09-27-10 11:18 AM
