ISF Front/Rear Strut Braces Installed
So if you remember I bought an RCF strut bar complete and test fitted it to see if does fit but requires modification. (still have it for sale by
the way)
I was not done with my search for more rigidity my search of previous post should that ISX50 strut bars would fir the F so I found these Ultra Racing 2pt. Front Strut Bar UR-TW2-830 For 2006-2013 Lexus IS250. What I liked about these it here is no pivot points they are solid pieces that mount to the top hats. Got the front and rear sets on ebay cost less then 300 for the set and test fitted and sure enough fits no modification needed. Now they only come in white so had them powder coated black for that oem look!
I sure the F is rigid from factory but the IS F CCS-R has additional bracing so Im sure it provides some benefit.
the way)
Strut bars look great in there! I'm sure there is some added rigidity in there as well. Loving the gutted look in the trunk as well. I'm assuming you've taken out your spare tire? How much weight do you think you were able to shave off?
Thanks!
Thanks!
I was under the impression that front strut bars have little to no impact to vehicle rigidity if the front suspension is a double wishbone set-up. It's explained in detail in this video from Engineering Explained.
