Key fob Features
Old 05-09-16, 07:48 PM
WillK
WillK's Avatar
Default Key fob Features
Just picked up a 2010 ISF and I noticed I'm not able to roll down the windows by hitting the 'unlock' button a second time.
Checked the manual and it says it's a dealer-enabled feature.
Is it true that only a dealer can do it? If so, I assume it's probably an hour labor to have it reprogrammed?
Old 05-09-16, 07:56 PM
liquidtek
liquidtek's Avatar
You hold the unlock button if it is enabled not double clicking unlock.
Old 05-09-16, 08:54 PM
WillK
WillK's Avatar
It's not enabled.
Old 05-09-16, 09:34 PM
Miqueaseli
Miqueaseli's Avatar
Also may sound dumb but is not. Check to see if you have an ISF key fob . My friend bought a 2012 ISF and it had an IS250 key fob programmed to his car . And also could not do this feauture
Old 05-09-16, 09:45 PM
WillK
WillK's Avatar
Yeah, good thought. The key fob does have the F logo on it so I assume it is correct for the car. The spare fob however, does not. I'll call the Dealer tomorrow and see.
Old 05-09-16, 09:53 PM
Miqueaseli
Miqueaseli's Avatar
Cool feauture to have especially in Nevada when its hot as hellllll.......
Old 05-09-16, 10:00 PM
mjeds
mjeds's Avatar
on my RCF the roll down feature is temperamental.
press once and unlock, then press and hold within 2 seconds of releasing the first press, hold for 5-7 seconds
Old 05-09-16, 10:06 PM
WillK
WillK's Avatar
Agreed...
I've tried several combos just in case. I'll be sure to try your suggestion too.
I know the feature worked well on my IS350....
Old 05-09-16, 10:34 PM
j3ff
j3ff's Avatar
Well if you bring the car in to the dealer for anything including recall work, they'll usually do the customization for free. That's been my experience in the past.
Your other option is to purchase Teachstream on ebay and do it yourself. It's about $40usd.
Old 05-10-16, 07:49 AM
scamsel
scamsel's Avatar
always wish it had the rollup and close sun roof feature as well, oh well
Old 05-10-16, 08:01 AM
Evil Teo
Evil Teo's Avatar
u will need to get access to techstream software to enable the option. I had done this to a local member about a week ago and his option was turned off and the dealer didn't want to do turn off his drl as I did it for him...
Old 05-10-16, 11:44 AM
digger08
digger08's Avatar
yup.....and you can also enable or disable the sunroof to open as well with the windows in the techstream programming options.
Digger08
Old 05-10-16, 01:25 PM
shyguyF
shyguyF's Avatar
Do you guys know what is the latest software and techstream cable working on our F ? I'm gonna update my F steering wheel ECU since I already had it. Thanks
Old 05-10-16, 02:28 PM
Bigjon3475
Bigjon3475's Avatar
Right. There's already a rain sensor...
Old 05-10-16, 04:54 PM
j3ff
j3ff's Avatar
I'm using v10.30.29. I believe there's a 11.xx also.
Quick Reply: Key fob Features
