REMEMBER THE NAME.....RR-RACING TUNE results...
As all of you know, I recently dynoed my F and got super low numbers. It was definitely caused by oil getting into the intake manifold from not checking the AOS can. I just came back from my dyno from another shop.
My car is still pulling timing but that's to be known after cleaning most of the oil out from my intake manifold. This is with approximately 644 miles after resetting my ecu and after cleaning most of the oil in my intake manifold.
The conclusion? RR-RACING ECU TUNE ROCKS!!!
All runs were done in 6th gear
Hood opened at all runs
5 min cool downs
SAE corrected numbers:
393.6 WHP 342.4 FT LB TORQUE
DYNOJET corrected numbers:
433.0 WHP 376.7 FT LB TORQUE
SUPER FLOW (STP) corrected numbers:
409.4 WHP 356.2 FT LB TORQUE
Wondering about my mods?
Power mods:
RR-RACING ECU tune
Deleted ALL cats
Custom 2.5 inch X pipe exhaust to borla mufflers
Other mods:
RR-RACING AOS
RR-RACING USRS
Everything else is stock.
I do not have a baseline number before the tune but I am DEFINITELY sure it is no where close to these numbers.
Feel free to GET THE TUNE!
5 min cool downs
Power mods:
RR-RACING ECU tune
Deleted ALL cats
Other mods:
RR-RACING AOS
RR-RACING USRS
^^Thanks you guys. I do feel a lot better now. As for cleaning the oil from the intake manifold, I used a VERY long screw driver and attached a towel at the end of the tip. I went through the throttle body and slowly cleaned the oil mess. Most of it is gone.
I ask the guy himself. He told me he only uses the air fuel ratio on his dyno if I wanted to dyno tune it. I didn't want to dyno tune it so he didn't include it in. It was a pricey dyno though..... $135 but he is well known to the domestic vehicle such as corvettes, camaros, mustangs....etc. His shop has awesome reviews and so far, I'm pretty happy too
I read your first thread and felt so bad for you. I honestly would have been so upset leaving the dyno with such low numbers and it would have drove me crazy. Good to hear you got some great numbers the second time around.
Now my question to you is this. You clearly have some seat time now with the tune and what are your impressions. My other question is, how does the f sound on the stock manifolds with gutted cats and borla exhaust? Does it sound similar to a header car?
I have borla catback and I wanted to do headers but I just don't have the money this year. I was thinking of gutting the primary's and getting the RR tune, that way I wont need a simulator.
The tune so far has been awesome. Mid range is greatly improved and so is top end. Gutting primary cats will give u a "blowing" type of sound. It's hard to explain it. I never had headers yet so I can't tell you that but gutting the primary cats did improved performance. If you get the tune, get the newer obd tune so that way, you can switch bwtween tunes and don't have to worry about the check engine light for the primary cats.
Fantastic news! Congrats on the numbers, looks like RR Tune might be closer than I have anticipated
