Has anyone tried the EBC brake pads?
Tech Info Resource
I have ancient HPS pads on my Supra. They suck compared to the Project Mu HC+800 I have on my F. I drove the cars back to back today, and I am ready to buy the Project Mu HC+800.for the Supra if they are available. As Matt said, the balance between throttle and brake is a whole lot closer with the HC+800. I was really disappointed with the Hawk offering after experiencing the Project Mu offeringl
Carbotech or Performance Friction and I'll leave it at that.
I ran EBC yellows and they were okay. They were able to haul me down from 155 miles an hour within 300 feet on the back straight at VIR.
I got project mu pads. They dont make noise like oem brembos, less brake dust and over all hasnt been a problem for me so far. I bought them on here from one of the vendors... just gotta search I forget who...
^^^^Forum Sponsor SpeedFreaks carries Project Mu and offers a CL Discount.
http://speedfreaksusa.com/search.htm...ect+mu+for+ISF
I am running Ferodo DS2500 pads in front and Project Mu HC+800 pads in back. A GREAT Combo IMHO.
Both sets bought from SpeadFreaks
Lou
Lou
Lou
Lou
I was using yellowstuff with slotted rotors on my 350z - I was very disappointed. Very low friction when cold, later problems with glazing, not so great when warm, noisy when used hard.
My good colleague had them on e90 330i and also he didn't like them.
Project Mu HC+800 is the way to go, but I only used them on my e90 330i. I bought set for ISF, but I first need to finish OEM ones.
Yes, my pads fit the stock calipers. Ferodo doesn't make pads for the rear of the ISF, but the Project Mu has worked out GREAT. I still have my OEM pads with a lot of life left in 'em. But, IMO, the braking capabilities I have now is far superior to stock in performance (both when hot and when cold) and with less dust.
Turing rotors is only necessary if the surface is not smooth and has high spots, even then I would not recommend it. If your rotors are still smooth and measure above the minimum thickness, there is really no reason to mess with them when changing pads.
Lou
Lou
^^^^Oh, sorry I misunderstood. Both the pads I have are dual purpose Street/Track. For street use only SpeedFreaks caries the Project Mu NS400.
http://speedfreaksusa.com/i-11667143...s-f-front.html
You don't really have to check the rotor smoothness, if it were not smooth you would feel it when applying the brakes - the pedal would pulsate. But, as I said above, measuring thickness is important.
Lou
Lou
Lou
Lou
Unfortunately, I do not remember which EBC pads they were. I do know it was supposed to be their highest performing pad at the time. There was an EBC-sponsored Celica GTS on the track as well that may have fared better given its significantly lighter weight and less power as well, by quite a bit.
I've tried Pagid, OEM Brembo, OEM StopTech, Hawk, OEM Toyota, OEM Lexus and Ferodo pads on my personal cars. For my Supras, I have Ferodo DS 2500s on my three MKIVs. I love these pads, but they, likely, dust too much for many in here.
When I need pads for my IS-F, I will be purchasing some pads Matt recommended to me via PM. I forget the brand/model, but they are pricey. According to Matt, he believes the performance is even better than the Ferodo DS 2500s, a pad he has experience with as well. I am hoping those pads, the OS Giken Super Lock LSD and the 2012 steering ECU get me exactly where I want to be with this car.
Ken.
Christian,
Ken.
Ken.
The pads Matt recommended may very well be the Endless MX72 compound, RC112 and RC119 pad shape F/R, respectively.
You are correct these pads are somewhat pricey... but damn are they worth every penny. Good bite out of the gate (or garage), even when dead cold, unbelievably good performance under repeated triple digit-0 stops, equally impressive under hard twisty performance driving, never seem to fade, quiet as a church mouse and very low dust.
I would purchase these pads again without hesitation.
Ken,
Thanks for this. I checked my old PMs (just deleted most them, but fortunately kept the ones from Matt) and you are correct. Matt highly recommends the Endless MX72s and a new pad by Project Mu he feels may be the best yet for our cars. It's called the Project Mu HC+800. They are also quite pricey but, suffice it to say, when I have to replace my OEM pads, it will be with either the MX72s or the HC+800s.
I currently run the NS400 for street and had intended to swap pads for track days.. However, I just bought a set of the HC+800 for the track and I'll gladly give up the hassle of swapping if they're a nice combination of track performance + livability on the street.
Come to think of it, I should probably just put 'em on now & see how they do for the next 3 weeks before my track day, but I like to hear other opinions too. Thanks.
-Mike
