CEL and check VSC WITHOUT headers !
Also check your AOS tube connections. I had one not properly seated which caused a vacuum leak and triggered multiple codes and limp mode. Data logs showed the car running really high fuel trims which lead my right to the culprit. Post your codes if possible and I'll compare to the ones I had. They were all over the place.
Just called and they are going to text me the codes. He said the car was throwing codes for running too rich. They said it was the MAF sensor that went and they are ordering a
new one. Not sure if this helps
will post codes later
This exactly what the tech told me its doing. He said its running really rich.
Tech Info Resource
Almost zero possibility of that. Air leak in the AOS or MAF issue are the likely sources. AOS would be more suspect as it is the one piece not tested by Lexus for reliability.
I waited all day and no codes. They just said it was the MAF sensor ad that the codes showed that the motor was running rich as hell. I told him that the AOS could have a seal issue that would produce a vacuum leak and codes. I told him I want him to have the tech tighten up all the bolts for the exhaust and to make sure the AOS hoses are secure. If there is any issues after the MAF is replaced tomorrow I will have them just remove the AOS until I can get a new one from Rafi.
I will text him in the morning for the codes again
I would like to thank each and every one of you for your help . Thanks guys.
Will update soon. I just want it fixed because track season is rapidly approaching and I dont want any issues. Just got a fresh set of rear AD08Rs and its time to play !!
Tech Info Resource
Only for a moment, then it would throw all of the available 20% correction rich into the equation. The ECM's job is to run the engine and fail to least possible damage when something goes outside normal parameters. So it will go pig rich instantly when there is an intake leak. AMHIK.
Thanks, Lance
These guys seem like they are guessing sometimes. You could probably school the shop foreman with your level of technical info and knowledge on this platform .
