What wheel specs will clear OEM ISF brakes?
I am looking at a set of used SSR MS1 wheels and the specs are so:
Fronts: 19x9.5, 25+ offset, HP disc
Rears: 19x10.5, 35+ offset, SL disc
In general, what should we look for to determine if they can clear our Brembos?
This may help: http://www.ssr-wheels.com/wheels/ms1_181920.asp
Thanks in advance.
Thanks in advance.
You should be ok it's usually the inner barrel size and its when you're down sizing there would be more issues. However some wheels and offsets bring in the spokes closer towards the caliper.
But here is a cool site you can compare how much offset there is compared to oem stock wheel specs
Willtheyfit.com
Willtheyfit.com
