Welding high flow cats to stock headers
Old 01-21-16, 08:18 AM
Diesel350
Diesel350's Avatar
Default Welding high flow cats to stock headers
Has anyone done this before? If so, how much HP is there expected to be with adding high flow cats?
Old 01-21-16, 09:22 AM
jat0223
jat0223's Avatar
After market high flow cats are usually not welded to the headers. They are welded to the exhaust. If you'd like to replace the stock cats on the stock headers I think you won't gain much for the amount of work involved
Old 01-21-16, 11:50 AM
lolfunxion
lolfunxion's Avatar
Next to nothing. The designs of the headers are restrictive more than the cats are. Maybe weight savings from a lighter wallet?
Old 01-21-16, 12:16 PM
Diesel350
Diesel350's Avatar
So gutting them out instead is the better option??
Old 01-21-16, 12:32 PM
ISFPOWER
ISFPOWER's Avatar
its cheaper, more power. and passes any visual test. downsides are being loud.
Old 01-21-16, 12:37 PM
lolfunxion
lolfunxion's Avatar
No, buying PPE headers is the best option. I don't think you make hardly any power on gutted cats. Once again, the design is the flaw.
Old 01-21-16, 01:11 PM
jat0223
jat0223's Avatar
Even though I have headers I have to disagree with you here. Gutting the cats provides close to the gains of headers. You gain the most from getting rid of the cats.
Old 01-21-16, 01:22 PM
tas02
tas02's Avatar
Before this thread spins out of control, you would only want to ADD high flow cats to the exhaust, not to the header itself.
FWIW, PPE sells their exhaust with high flow cats already installed.
Isfv8 (05-31-20)
Old 01-21-16, 01:30 PM
Fsport2UR
Fsport2UR's Avatar
That is only typical on other cars. Dyno results show similar gains for gutted cats on stock ISF headers compared to aftermarket headers. The stock cats are the restriction, not the header design.
Old 01-21-16, 02:09 PM
flowrider
flowrider's Avatar
Received 1,826 Likes on 1,288 Posts
^^^^I have not seen that proven anywhere The exhaust manifold design on the ISF is terrible IMO.
Lou
Attached Thumbnails Welding high flow cats to stock headers-factory-exhaust-manifolds-is-f-manifold-a.jpg
Old 01-21-16, 03:53 PM
MileHIFcar
MileHIFcar's Avatar
Can you please post up a link or a pic of a dyno run of someone with an aftermarket exhaust (Joe-Z/Borla/ISS etc....) with gutted primaries that is putting out the same numbers as PPE/Sikky headers gains???
Just curious, because I have never seen one posted here on CL of a dyno run with gutted primaries/aftermarket exhaust only......
Thx
Old 01-21-16, 04:31 PM
nickj718
nickj718's Avatar
Rafi and his race car has gutted cats and not headers. Has to be a reason for that because it sure isnt laziness
Old 01-21-16, 05:27 PM
Sylvan
Sylvan's Avatar
There have been multiple threads about it, one was even a gutted cat car racing a header car and the race was so close no one would even admit losing.... Save yourself a pile of time and money and gut your cats.
Old 01-21-16, 06:31 PM
Diesel350
Diesel350's Avatar
And smelly?
Old 01-21-16, 07:13 PM
ISFPOWER
ISFPOWER's Avatar
And smelly?
long tube headers are smelly too. deleting any catalytic converter on any headers, you will see power gains.
Quick Reply: Welding high flow cats to stock headers
