Brake pedal requires a LOT of force to start the car (VIDEO)
LOL I just went through this with my SA. The car is fine. What happens is when you get in the car you dont realize but you keep stomping on the brake pedal to get situated. When you press the pedal a few times the pressure gets pretty high and then you need to push really hard to get it to the point where it will start. LOL He said he had 2 people with IS350 and one ES this month with the same complaint. He even watched the people get in and start the car and pointed out to them how many times they stomp on the pedal getting situated and putting their belt on. Mine did this after my last track day when I got home and I was cleaning the interior. I went to start it and the pedal was rock hard,. I even freaked out and took it in right away. My car was fine
. I think they are replacing it because they can,
If you dont believe me stomp on your brake pedal 4 times before you start it . $50 says it feels like a rock when you go to start it
I would have let them replace it also. New parts are new parts .lol Just dont want you worrying about it
same here....i use my car once or twice a month...everytime i start it for the 1st time,the brake pedal will be super hard...i would step on it super hard until the PUSH START light will turn GREEN....once the car starts the brake pedal will go down all the way like it would normally
Dealer had my car for 2 days while I was getting new tires. They claim they never could reproduce the issue so they did not fix it.
Is this an easy procedure and does anyone have instructions on how to replace the valve?
Received 1,058 Likes
Mine just acted up two days ago... Leaving from home and then work..
Brake pedal felt like a brick on first start up..
Thanks to Lobux's recommendation I cleaned mine with brake cleaner last night.. Soo far today the pressure remained in the brake booster..
If it keeps acting up or fails again, I will just order a new Brake Booster Check Valve & Grommet
2008 - 2014 • IS F Part Numbers:
44730-28030
90480-24015
Essentially as these things get old, they lose their ability to hold the boost over a long period of time.
Here are the pics I took last night..
Joe Z
44730-28030
90480-24015
Joe Z
Thanks Joe!
So it looks like you just pull it out of the grommet and then push the new one back in. I kept looking for a way to get a wrench on it and grab somehow!
This means the grommet was still good..
Once you release the hose clamp and remove the hose..
You may need to use pliers or a flat head sandwiched between the grommet and valve to pry it out..
Do not pry against the brake lines or brake booster.!!
Be ready to grab it, if there is any boost left in there it will pop out fast..
Or first with the car OFF - just go pump the brake pedal till all the air is depleted..
For cleaning: I used brake cleaner to flush out the check valve and made sure to press the valve with the red squirter to make it flow while flushing at the same time..
Once it dried up I reinstalled... Grommet first - then the check valve.
If it happens again, I will swap out for new parts.. Even the grommet since its only a couple of bucks..!!
** Clean the valve at your own risk..!! **
** DO NOT spray brake cleaner into the check valve while still on the Brake Booster **
** Remove entirely, clean, let dry then reinstall..!! **
Joe Z
Well I got the new valve installed along with a new grommet and I can't say that it has made a noticeable difference. Sometimes the pedal feels "normal" and other times it is hard to depress. Does anybody have a suggestion about what I should check next? Should I think about replacing the hose that connects to the valve? Thanks!
Hopefully it's not the brake booster itself..
Joe Z
Tech Info Resource
The hose is possible but pretty unlikely. Sounds like the booster has issues. Do you have warranty left, or is this an out of pocket repair? If it is the booster, it won't be anything like cheap.
i replace the valve and the rubber gasket and my brake pedal is still hard to depress on start ups....but once the engine is running,the pedal feel becomes normal.....i will check the hose for any crack or leaks.....i hope its not the booster
