Is it safe driving around with 1 sheared bolt?
Old 11-10-15, 12:15 PM
Defratos
Defratos's Avatar
Question Is it safe driving around with 1 sheared bolt?
So the garage who installed my tpms over torqued the wheel nuts, I got them all out and put them back in to my usual setting. 1 bolt sheered of so is it safe driving around like this for a few days until I get it into the dealers?
If it makes a difference it's the rear passenger wheel.
Old 11-10-15, 12:16 PM
Vervish
Vervish's Avatar
I think it will be fine - just lay off any aggressive cornering.
Mine snapped too and I drove a few days without any problems.
Old 11-10-15, 12:20 PM
I8ABMR
I8ABMR's Avatar
I think it should be fine. Just keep off the track lol.
Old 11-10-15, 12:29 PM
chris07is
chris07is's Avatar
You should be good, but get it fix asap. And yeah, just don't drive aggressively.
Old 11-10-15, 12:37 PM
Defratos
Defratos's Avatar
Thanks for the help.
Now what is usually the fix for this? do they replace the whole hub assembly?
Old 11-10-15, 12:49 PM
imp0rted1
imp0rted1's Avatar
after removing the rotor you should be able to punch out the stud itself and press a new one in
Old 11-10-15, 12:59 PM
KLexus50
KLexus50's Avatar
This thread should give you most of the info you need.
Old 11-10-15, 04:26 PM
FNSSESPORT
FNSSESPORT's Avatar
I Would make sure they dont "punch" out the broken stud. Best to press out the old one and press in a new one.
Old 11-10-15, 05:26 PM
Compthis
Compthis's Avatar
You better replace every stud. Just because the others were not broken, doesn't mean the studs aren't stretched.
Old 11-10-15, 07:29 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,848 Likes on 2,333 Posts
There is wisdom in this, and new studs are cheap even from Lexus.
Old 11-11-15, 04:15 AM
roswell
roswell's Avatar
I agree, since all the studs will be accessible on that wheel I would just change all 5 to be safe so u don't pay labour again down the road.
Old 11-11-15, 05:57 AM
imp0rted1
imp0rted1's Avatar
from a few threads down
https://www.clublexus.com/forums/is-...heel-stud.html
Old 11-11-15, 06:16 AM
KLexus50
KLexus50's Avatar
Originally Posted by imp0rted1
The exact same thread I hyperlinked in post #7 if you scroll over 'This'.
Old 11-11-15, 11:11 AM
Defratos
Defratos's Avatar
Thanks guys and sry for the repost on the same topic, should have searched first
Old 11-11-15, 12:49 PM
Compthis
Compthis's Avatar
If the op had all wheels worked on he needs to change all 20. The shop may have a torque wrench that maybe set to 85-90lbs but could be out of calibration. My buddy had his wrench set to 100 and ripped a stud right off his Corvette Z06. The calibration was way out and that was because he didn't put it away set at zero. He was forced to replace them all because he couldn't be confident out on the track. Be safe OP, you don't want to catch a hard corner and off goes your wheel.
Quick Reply: Is it safe driving around with 1 sheared bolt?
