URGENT: Damaged brake line, question on repairing/replacing it
Old 11-09-15, 05:47 PM
mshab356
mshab356's Avatar
Default URGENT: Damaged brake line, question on repairing/replacing it
Hi all,
I have a 2008 IS-F. A friend of mine was helping install my new JoeZ exhaust this weekend and accidentally knicked the brake line that is situated next to the right (passenger) side catalytic converter. Naturally, it bled the brakes dry and I had to get it towed to the nearest Lexus dealership since there was no braking. They quoted $3700, saying that they need to drop the engine to reach and replace the whole line. Is this true? I find it hard to believe that the whole engine needs to be dropped for something fragile that can easily break/get damaged. Any advice would be greatly appreciated!
Old 11-09-15, 06:47 PM
NotADood
NotADood's Avatar
you could call around and find a shop willing to install a double flared compression fitting. It is possible to repair it, just not worth the liability for most shops. I would try a hot rod, 4x4, or tuner shop as they do more custom work.
Old 11-09-15, 07:29 PM
MK4Sup_isF
MK4Sup_isF's Avatar
I have a new set of braided lines from Racing Brake if you want to get them. Ohh wait, the hard line. Find a salvage 2nd gen isX50. Don't know about his labor intensive it is to install though
Old 11-10-15, 05:36 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
Originally Posted by mshab356
Hi all,
It's true for a dealer. Not true for an independent. Replacing hard lines is a PITA, and bleeding it well is also a challenge because you'll need to cycle the ABS valves (you need Techstream) to ensure you don't have air trapped in the ABS control unit.
I could see it being $500, but not $3700 and engine drop. They are just trying to make it easy for themselves, or make it so expensive you won't choose them to do the work.
Old 11-10-15, 08:05 AM
mshab356
mshab356's Avatar
Thanks for the responses everyone. Just had the dealership do what they need. Dont want to risk modifying the brake lines for it to fail later.
Old 11-10-15, 10:03 AM
I8ABMR
I8ABMR's Avatar
WOW $3700 !!! speechless
Old 11-12-15, 03:20 PM
Fsport2UR
Fsport2UR's Avatar
Well.. that sucks. I would of at least got a second opinion at another Lexus dealership. Sounds like the head-hancho mechanic there doesn't know wtf he's doing. $3700 is just unbelievable for a measly ol brake line.
JP250
08-04-14 02:40 PM
Tulsa1
Southwest
09-16-11 10:53 AM
Benjamin T
Suspension and Brakes
08-15-07 08:33 AM
mcnelson
09-04-02 05:37 PM
Quick Reply: URGENT: Damaged brake line, question on repairing/replacing it
