Questions about Swift Springs......
Since you can choose your spring rates for the swift upgrade when doing the BC coilovers, I was curious if you buy them as stand alone units can you still choose which spring rate you want (ex..14/10k...16/12k...18/14k etc....)??
Also for the guys who have installed swift springs on the stock shocks, have you seen an increase in performance (better cornering, better control etc..)? Or are they purely cosmetic for the slight drop that they give the F??
Thx guys
Thx guys
I am running the front springs only on stock shocks and I love them - handling/performance are about the same IMO. I did not notice any degradation in performance nor did I notice a dramatic increase.
Comfort also stayed about the same on my 2011. My observations are purely street driving, I have not tracked the car.
None.
Did you guys have an option to choose spring rates for the Swift springs like you can with coilovers?
I found the spring rates for the Swift springs:
Attached screen shot shows 8k rear & 9k front........... Why are they so soft? Not a suspension guru by any means but most guys are getting 14/10k on the swift springs when they order BC coil overs and even more maybe are going with 16k/12k spring rates......... what am I missing here??
Here is the screenshot:
You decided to just do the fronts only? So in essence you have different spring rates for the front and rear?
Not a suspension guru either, but I I think the low spring rate is a result of them being designed to work with stock shocks. Too high of a rate and the stock shocks would be overwhelmed and you would have a bouncy ride. This is not the case with coil overs - which in theory, have stiffer (and adjustable) valving.
I concur with the others. I installed them on my 2008 this summer, there really isnt any noticable difference from stock, which is what i like, because i like the stock feeling. My only complaint is i wish the back springs lowered the car a full inch like the front.
I do not know what the stock spring rates are vs the swifts - but I was looking to have a slightly raked look. I made the change for aesthetics, but the good news is handling was not noticeably effected either way.
Curious is anybody knows what the stock spring rates are? And if they are similar to what swift put theirs at?
From my observations the springs were nearly identical in height from stock to swift. But the swift were much easily compressed than the stock springs, hence it sits lower with the weight on it. As far as performance i would say no change, lowered the center of gravity a hair but nothing durastic. Bumps seem to be absorbed well in the road hence the softer shock. Havent had any issues with speedbumps or bottoming out, cheap alternative and essentially problem free to erase that wheel gap. I know you've heard this from me gabe, but just wanted to chime in on it. You pose some good questions on factory spring rates, ill check back in, i could use some knowledge in suspension.
