Carbon Ceramic brakes
Old 09-22-15, 10:37 AM
SpeedFreaksUSA
Former Sponsor
SpeedFreaksUSA's Avatar
Originally Posted by ZaxF
Most excellent response Matt! (Queue air guitar solo ala Wyld Stallions). That's exactly what I was looking for and hopefully you've saved some of the 'ballers' out there a chunk of money too.
There are a lot of misconceptions about CCM so I'm happy to help shed some light if it saves people thousands of dollars and a lot of cursing
Originally Posted by Bigcloud
I have a buddy that has a 997.2 GT-3 and he converted to iron immediately. I do a lot of events with the Porsche Club of America and just about all the cars that came with CCB's have been converted. So speedfreaks is right.
PCCBs are phenomenal for anything up to really aggressive street use and occasional light track use but sustained heavy track use burns them up quickly. Porsche is happy to charge you around $10K each time you fry the brakes but that gets old fast, even for the more elite track day gentlemen.
-Matt M.
Old 09-24-15, 08:43 PM
FIGS
The Maker
FIGS's Avatar
Note that not all CCM kits are equal and spcial attention should be paid to the rotor manufacturer and more importantly the pad itself.
RB has made huge strides on making CCM technology track viable with a sintered CCM specific track pad that is being tested on many platforms. A technical review can be found in the GTR forums.
http://www.gtrheritage.com/topic/446...th-ccm-rotors/
The general state of the technology is that ST makes the best ring for sustained high temp usage and RB is quickly carving out their niche as the premier CCM pad supplier and ring integrator. ZR1 discs are also used for cost effectiveness and supply. The vast experience that RB has with braking thermo and materials science coupled with direct engineering access is one of the primary reasons why they are our exclusive braking solutions partner. The best components make the best products and that is why we feel that RB has the best solution in the CCM space, regardless if its an OE kit or not.
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 09-23-22, 01:20 PM
autovation
autovation's Avatar
Bumping an old thread, has anyone run CCB's on the IS-F?
Old 09-24-22, 07:11 AM
FIGS
The Maker
FIGS's Avatar
we are moving forward with the hat design for the 380x34 front kit. If intersted just shoot a pm with your info.
Mike
__________________
The following 4 users liked this post by FIGS:
JT2MA71 (09-24-22), lobuxracer (09-24-22), MileHIFcar (09-24-22), minator (09-24-22)
Old 10-13-23, 11:59 PM
autovation
autovation's Avatar
Checking in to see if there are any new updates or data? I saw 1 person on IG that purchased the CCB kit but I have not found anyone else who is running the RB CCB kit. Would be interested in total weight savings also, I see the weight savings for the rotors but not the calipers?
Old 10-14-23, 10:46 AM
JT2MA71
JT2MA71's Avatar
Received 1,511 Likes on 655 Posts
Calipers are bigger than the factory calipers so there’s a little bit of weight gain there. But still, overall, there’s substantial weight loss.
Old 10-14-23, 03:44 PM
autovation
autovation's Avatar
Here are the Carbon Ceramic Kit Weights from @low.is3 on Instagram:
380mm front - 13.88lbs
380mm rear - 13.60lbs
6 piston front caliper w pads -14.04lbs
4 piston rear caliper w pads - 9.78lbs
dunnojack
05-27-14 02:11 PM
bigblack06
05-13-14 01:38 PM
Eug421
06-24-07 04:10 PM
Overclocker
12-29-06 10:41 PM
Quick Reply: Carbon Ceramic brakes
