08-09 Bluetooth audio
What do you guys use to stream into the audio, spotify/pandora whatever - tried a griffin itrip aux and it is just unbelievably bad, more static than music + makes this weird whining noise during acceleration. Hoping someone on here has some ideas/solutions, thanks.
Also even though the title says bluetooth it definitely is not required, if the best solution is plug-in id love to know it.
I bought a Lotfancy Bluetooth receiver for streaming music on my 08. It plugs into aux with another connection that goes into usb for power(used a usb adapter in power outlet). There's no mic, so it can switch from music to answering a call in a snap. Only thing is that you need to turn it on everytime you get in. Only paid $10 for it.
It sounds like you need to purchase a ground loop noise isolator. I paired this one with my blackberry music gateway and it eliminated the static.
Amazon.com: PAC SNI-1/3.5 3.5-mm Ground Loop Noise Isolator Works with iPod/Zune/iRiver and Others: Automotive
grab a Bluetooth interface module that emulates an external CD changer. Gives you track control from the steering wheel and stereo.
Here's one from GROM Audio
http://gromaudio.com/store/bt3_adapt...e_adapter.html
Tech Info Resource
The whine is caused by a ground loop. If you have power and signal in the same device and the signal ground is not isolated from the power ground, it's going to make noise. I get around this by using my phone as my music source and using a wireless (Qi) charger while I am playing music.
I thought about the BT modules, but they're going to have ground loop issues no matter how you slice it unless you put in the filter referenced above. Lexus identified this as a problem years ago and had a service bulletin on it complete with parts to fix the issue, but they've since incorporated a better method of connecting, so it isn't needed on later model cars.
11 Second Club
I've had some luck with the ground loop device I was using in the past, but recently tried a aux to Bluetooth device from Amazon called Mpow Bluetooth Receiver and it works great with no more whine noise through the aux! It automatically pairs with your phone, is very small and the sound quality has not changed. Highly recommended esp with the $15.99 price!
RJMacReady (11-30-22)
you'll get no whine while its running on its own battery. id assume it would make noise if you were charging it at the same time.
grom vline may be the way to go.
11 Second Club
I have not tried running it while charging. Should only need charged once a week or so and though it's slightly inconvenient to take 3 seconds to turn it on each time, I don't mind. For the price and the fact that I now have one less cable plugged into my phone and the whine is gone. I'm happy!
Been running the devices in my sig for over a year with zero issues. One annoyance though - calls are louder than music when switching over. This is caused by the device itself, not the phone.
There's a firmware update for it which'll probably fix it but I'd need to pull out my radio again...
