switching up/down shift on center console
Is there a way to switch the down and up shift in "M" mode. ( backwards for up shifts and forwards for down shifts)
Yes. There is a thread or two around that gives the details on the necessary wiring changes. Or if you just want a plug and play option, Tom's sells a kit that will do the trick. http://www.tomsracing.co.jp/products....php?mprID=265
Tech Info Resource
this mod would make Matt Farah happy. He criticized the ISF for the shift directions not being the same as the motor sport applications. In the end if you dont drive with the paddles you are just doing it wrong
-Mike
