Show us your suspension work!
Rough installed today:
Figs race arms, full link set, end links, flca rear mount, next is flca front and fuca offset bushings paired with spc upper ball joints and new oem lowers. Rear knuckles are getting all the figs bushings (need to order the sphericals and going to put in new wheel bearing units.
Jic magic flt-a2 coilovers installed a couple weeks ago
Sikky sway bars installed a couple months ago
Custom subframe braces
Should be done adjusting tomorow then off to check the alignment, not set on a final install as of October I'll be going full widebody and a lot wider wheels on a corners so I'll be readjusting all the stuff to accommodate.
Thank you Ron! It's some amazing stuff honestly, easy to adjust and the ends are top notch. I've had several cars with multi link suspension and always done the installations. This was a bit more of a pita due to the cam bolt on the toe rod, I couldn't get the bolt back in the way it was so I put it in the other way and was still able to get it tight, figs listed to put the bolt in all the way inboard basically not utilizing it due to the threaded link for adjusting. The other problem was that I had my sikky sway bar on the stiffest setting and it was appearing to almost bind on the rear control arm along with the endlinks so I put it in the middle and called it good, I rather have in the middle setting (specially with coils now vs the stock suspension). Other than that I'm just waiting to get the new front lower ball joints, new wheel bearings and the remaining figs bushings
Justin, you're an extremely lucky guy. I bang my head to the wall every day because i didnt jump onto this deal when it was still available. Now i gotta order a bunch of links and arms from Figs to pull in my aggressive set up.
Looks great! What on earth do you plan on doing with all that adjustability?
Are the cam bolts hard to get in because of the new adjustable link? I replaced my cams with new parts when I did my toe links.
Putting the cam inboard as far as possible is a smart recommendation, it makes the toe links as long as possible, with minimizes the toe changes as the suspension cycles.
Are you getting OEM ball joints, or something else (ie. Moog, etc.)?
Tech Info Resource
I won't plan to do this until I have a full model of the rear suspension so I know the impact of any adjustment I make from a camber and toe perspective.
Tech Info Resource
I know I sound like a broken record, but knowing the roll center(s), roll axis, instant centers, scrub radius, and a host of other very important measurements makes all the difference in the world to your chassis setup. Measuring the chassis is still on my to do list, but I think it is critical to know what is happening if you are installing links with the ability to fundamentally change the length.
