Any suspension guru's out there?
To my knowledge, the platform has remained the same for all IS's thru out second gen. I have a set of BC coilovers from my 2008 IS350 that I never installed , so they are brand new and still in the box. I opted to have the Swift springs installed on them with 14k fronts and 12k rears. So I contacted BC to determine compatibility on the F, and they said they changed the design of the strut for the 2013 MY. They suggested I sell the ones I have now and purchase the newly re-designed ones.
This sounds like B.S. to me, But before I go popping off, I would to get some input from the pros.
The spring design changed for 12+ but thats only for OEM struts. The coilovers for the ISF is not year specific.
Also, I would be against using ISx50 dampers on an ISF. I've done that and it was a TERRIBLE experience. It made the ISF drive worse than stock. The ISF weighs more and definitely needs the coilover valving to compensate for that.
Tech Info Resource
How deep do you want to get in this quest?
The real problem is no one is telling what optimum ride height for our suspension is. Without knowing what the camber curves look like and what the natural frequency of the setup is, it's all just guessing. I have asked for this more than once from all the sources, but no one seems to have done the homework. If you measure your chassis and produce the requisite camber curves, you can figure out what setup is best for street or track. They are not the same, and there is no compromise if you are looking for ultimate mechanical performance. I know full well arbitrarily dropping the ride height will potentially put the roll center below ground level which will only make the car look good, but will not make it perform well.
Anyone coming from a real suspension tuning background will either chuckle or LOL at some of the recommendations we have seen here. It's not intuitive and hitting the marks by trial and error will result in a large stock of useless springs and dampers. If you don't do the homework, don't expect superior results.
When I finally take the time to measure it, I will post what I learn here. Those interested in getting the most (mechanically) from their cars would do well to do the homework and understand what the chassis will and won't do. Again, arbitrarily dropping the ride height is more likely to cause problems than to solve them.
We learned years ago that the Supra performs best at stock ride height. I am not confident this is true for the F simply because flipside909 alluded to the ride height being adjusted upward in the production versions to ensure the bumper would not hit parking stops. If this is true, there is some drop necessary to optimize the camber curves and we do not have this with the stock ride height.
The Maker
They are talking about their (BC) design. They improved the rubber upper hat to address the issue with center tube not contacting the thrust washers. It is a nice improvement for anyone that previously had to go through the extra torque on the center nut to assure the bushing would compress. minor details elsewhere as well, but that is the big one.
Mike
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Thank you Mike, for describing the for the differences in the designs. Now the million dollar question, Would you recommend to purchase a new set, Or install the ones I currently have?
The Maker
It really depends on what you want to do with your car and what mods you will make plus if it will see any track time.
Mike
__________________
737NG
09-10-15 06:54 AM
brociouz
Suspension and Brakes
06-18-14 10:09 AM
mikellucci
03-14-14 08:40 AM
