Found a 2008- What to Look For...
Sorry for the long post...
I currently have an '08 IS350 and love it but I found an 08' F with 64K on it that I may look at.
Checking the Lexus service record, here's what's been done in the last 20K miles:
6/18/2015 64161 0874401 INTERNAL DETAIL INCLUDES: REMOVE BUGS AND TAR, REMOVE MINOR SCRATCHES, WASH AND WAX EXTERIOR, CLEAN ENGINE, STEAM CLEAN CARPETS AND - INTERIOR DETAIL. PLASTIC ON CARPETS - COMPLETED
06/18/2015 64161 0874401 CAMPAIGNS CHECK FOR OPEN CAMPAIGN/RECALL - RECALL COMPLETED - 1093038 06/15/15
06/18/2015 64161 0874401 DRIVEABILITY SCAN FOR FAULT CODES - NO CODES
06/18/2015 64161 0874401 GLASS CHECK TINT FOR MSI
06/18/2015 64161 0874401 GLASS REMOVE TINT
06/18/2015 64161 0874401 EXHAUST SYSTEM INSTALL EXHAUST
06/18/2015 64161 0874401 REPLACE 2 TIRES REPLACE, MOUNT AND BALANCE 2 TIRES - COMPLETED
06/18/2015 64161 0874401 EXPRESS LUBE SERVICE PERFORM OIL AND FILTER CHANGE $34.95 PLUS SHOP SUPPLIES/TAX - COMPLETED OIL AND FILTER CHANGE.
6/18/2015 64161 0874401 BODY HARDWARE REPLACE WIPER BLADES
06/18/2015 64161 0874401 FOUR WHEEL ALIGN PERFORM FOUR WHEEL ALIGNMENT TO FACTORY SPECS $99.95 PLUS SHOP SUPPLIES RECOMMENDED EVERY 12 MONTHS OR 12,000 MILES ASK US ABOUT LIFE TIME TIRE ROTATIONS - ALIGNED ALL 4 WHEELS TO SPECS. COMPLETED
06/18/2015 64161 0874401 RADIATOR REPLACE REPLACE RADIATOR
06/16/2015 64276 1093038 ELFREPL FUEL PRESSURE GASKE T - IS F,GS460,LS460,LS600H - CAMPAIGNS - ELF - ELF SERVICE - 64276 PERFORMED ELF. GAS
06/16/2015 64276 1093038 ELEINSP FAN/REPL SCREWS - CAMPAIGNS - ELE - ELE RECALL - 64276 PERFORMED ELE.
05/10/2014 48788 0251367 REPLACED FRONT BRAKE PADS AND ROTORS,
05/10/2014 48788 0251367 REPLACED REAR BRAKE PADS AND ROTORS,
02/28/2014 43180 0244848 WATER PUMP ASSY &/OR GSKT C/S: COOLANT LOSS, UNDER CAR SPLASH SHILEDS - BEARING HOLE LEAKING - 43178 REPLACED WATER PUMP AND COOLANT.
02/28/2014 43180 0244848 REMOVE SERRATION PATTERN & INSTALL NEW WIPER ARM NUTS SAFETY RECALL DLA - REMEDY NOTICE - 2006 THROUGH EARLY 2012 MODEL YEAR IS 250 AND IS 350 2010 THROUGH EARLY 2012 MODEL YEAR IS250C AND IS 350C AND 2008 THROUGH 2011 MODEL YEAR IS - F FRONT WIPER ARM NUT. - OPEN CAMAPIGN - 43178 REPLACED WIPER NUTS AS PER LEXUS
02/28/2014 43180 0244848 REPLACE INTERNAL TRUNK RELEASE LEVER PRODUCT UPDATE DLB - REMEDY NOTICE - CERTAIN 2006 TO EARLY 2013 MY IS 250 IS 350 & IS - F CERTAIN 2007 TO EARLY 2013 MY ES 350 & ES 300H & CERTAIN 2013 MY GS 350 & GS 450H VEHICLES - INTERNAL TRUNK RELEASE LEVER (HANDLE). - OPEN CAMPAIGN - 43180 TECH PERFORMED OPEN RECALL DLB ON CUSTOMERS VEHICLE.
The car looks to be in good shape with fairly low miles. It appears the radiator and water pump have been done, which I know are known issues.
Is there anything else I should look for in checking this car, besides the obvious, leaks, squeeks, stains, etc...
Thanks-
Thanks-
My recently purchased 2011 has an intermittent leak on the driver's side of the engine bay, with telltale *psssttt* sound as it drips onto hot metal...something you could easily detect after a short drive.
I'd check bellypans and covers for signs of leaks as well as sides of the engine/trans for residue. Check panel gaps for alignment. Brakes done last year so check rotor width and pad width. A full PPI at the shop of your choice would be ideal.
Your list looks complete for all the recalls. Might want to pop the plastic engine cover off and check to make sure your "plastic wire cover" isn't held together by tape. Quite a few members have had this issue at other dealerships.
Thanks everybody. The other thing I'll add about this car is it's at a non-Lexus dealership but the car was sent to a Lexus dealership for all of the service listed on 6/18. Also, it did just complete Maryland State Inspection.
If it completed MD inspection then you should be good with regard to the general condition of suspension, mounts, axles, lighting, and fuel. Car would need minimum brake pad and tire tread depth to pass as well.
