Started building my own exhaust!
Old 07-30-15, 10:41 PM
Jermstn
Jermstn's Avatar
Default Started building my own exhaust!
I started building my own exhaust as I mentioned in my other thread (acquiring my 2nd ISF), I work two jobs so finding time is nearly impossible, averaging 12-14 hours/day between the two. Anyways I started with the axleback section because it is the easiest.
I did run out of time tonight but I got majority of it done and I will be revisiting it later! I rushed alot of the welding (autogenous, and some filthy big gaps w/ 1/16" rod) because I was impatient and I couldnt align the exits directly through the quad stacks nicely. Gets fairly warm under there as my hand can attest too after the drive home.
I made the axleback section from 3" piping from Treadstone performance 304SS, I believe it to be .049 to .065 wall thickness based on welding amperage. It also looks way more elaborate than it needs to be (didn't have time to use hangers at the rear of the mufflers so the midpipe ones had to do, welded some tabs and used poly hangers and it doesnt rattle at all!!) I used ALOT of my scraps and pie pieces from other projects.
Old 07-30-15, 11:39 PM
idoke1
idoke1's Avatar
Looking good. Are you only custom frabricating a axel back exhaust or the full catback?
Old 07-31-15, 12:38 AM
teamcalvin
teamcalvin's Avatar
looks great man, send us a video when it's done!
Old 07-31-15, 10:55 AM
LukeRich
LukeRich's Avatar
Good choice of 304.
316 always tricks ppl..more $$$$ must be better.
Old 07-31-15, 11:47 AM
cremaster
cremaster's Avatar
looks good. any reason you went with 3 inches instead 2.5?
Old 07-31-15, 03:07 PM
Jermstn
Jermstn's Avatar
I will eventually be doing the entire catback, free time pending!
Originally Posted by LukeRich
Good choice of 304.
Yea definitely, even the 304 downpipes Ive down for high horsepower cars (600+) have zero issues. Although I have done some 321 SS stuff, customer requested obviously.
I had the most scrap in 3" piping otherwise I would have totally done 2.5"
Old 07-31-15, 04:20 PM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Good choice of 304.
I recently heard a funy story that 321 SS weighs less than 304 SS
~ Joe Z
Old 08-01-15, 06:07 AM
Jowett
Jowett's Avatar
316 has moly, which will deal with salty roads far better than 304 at the temperatures auto exhausts operate in. Want a tip that needs minimal polishing?
Old 08-01-15, 07:03 AM
Jermstn
Jermstn's Avatar
^ You are right but also not in depth. 316 certainly does have better corrosion resistance properties, better than martensitic stainless steels such as 400 grades which are usually higher in chromium (affecting hardness at low operating temperatures) and is used in the factory ISF exhaust (probably 409 SS). Molybdenum usually affects the hardenability! Nickel is the element you are looking for when talking corrosion resistance, 304 is almost never said in industry. We refer to 304 stainless as 18/8 or 316 as 18/10 - 18% chromium 8%/10% nickel. If we speak in ASME or similar codes while welding stainless piping we pay extra attention to B31.3 - Severe Service, where weld quality and certification is scrutinized heavily, especially since nickel content can be lowered via welding.
Old 08-01-15, 01:53 PM
Joe Z
Joe Z's Avatar
Lightbulb
If you decide to make the rest eventually, I would use the 2.5"..
3" dual would just be to large for the exhaust flow..
IMHO you might even lose some HP
Joe Z
Old 11-07-15, 09:35 AM
Jermstn
Jermstn's Avatar
Way late on posting the video but seeing a few muffler delete threads popup I figure mine should help answer some quesitons.
http://vid20.photobucket.com/albums/...psuhlijm02.mp4
Old 11-07-15, 09:42 AM
DCoolBeans
DCoolBeans's Avatar
Looks great man!
Old 11-07-15, 11:19 AM
tas02
tas02's Avatar
Nice sound. Can't wait to get system I ordered in September.
Old 11-07-15, 11:33 AM
Joe Z
Joe Z's Avatar
Question
What did you order in September ??
Joe Z
Old 01-13-16, 09:27 PM
nikogio38
nikogio38's Avatar
Looks good, but how does it sound?
Quick Reply: Started building my own exhaust!
