Oil change intervals?
Old 07-14-15, 07:51 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,847 Likes on 2,332 Posts
Originally Posted by kauaian
Which series are you running?
Have you ever had it analyzed?
I wonder how that 25k interval actually holds up?
Why such close intervals? That's supposed to be some serious stuff.
It would take a very low iron content for me to even consider 25k miles as reasonable. Iron tracks mileage, and iron content in the oil is the most important number behind silicates. If you have silicates, you have bad air filtration. If your iron is high, your oil has run a long time and become abrasive. So, if you want to run a 25k mile OCI, you'd better plan on sampling at 10k, 15k, and 20k to check iron content. You'll also want to spend the extra $10 for TBN to see if there is any base left in the oil to neutralize the acidic byproducts of combustion. When TBN goes below 1, you are in the danger zone.
Old 07-14-15, 10:30 AM
2URGSE
2URGSE's Avatar
I've tried Castrol Syntec until I saw what the oil looked like during the drain after a short interval.
Switched to RedLine Oil 5W-30, oil lasts much longer and the car runs much smoother. Toyota OEM filters.
My buddy who had a 2008 ISF at the time switched as well and said he noticed a big improvement.
Old 07-14-15, 11:36 AM
Bulls23337
Bulls23337's Avatar
Originally Posted by zojirushi
I did 10k miles on my most recent oil change with mobil 1 synthetic. Blackstone summary recommended 12k OCI for the next one.
What oil filter are you using?
Old 07-14-15, 12:11 PM
LukeRich
LukeRich's Avatar
oh the ol 3k/3mnth myth. I remember trying to tell people this before the internet and ppl would get upset. But Empirical data always wins in my world.
Old 07-14-15, 12:38 PM
semnosNSX
semnosNSX's Avatar
How many miles does it take before the oil maintenance light comes on? I think it's around 5k-7k. Anyway, that's how often I change mine using Mobile 1 full synthetic and OEM filter.
-Steve
Old 07-14-15, 12:46 PM
VDODSON
VDODSON's Avatar
Every 3K miles is a waste of money.
Old 07-14-15, 12:52 PM
JT2MA71
JT2MA71's Avatar
Received 1,512 Likes on 656 Posts
I also use Amsoil (signature series) 5W-30. I switched to it when I drained the factory oil at 3500 miles. I went 6000 miles with the Amsoil just because engine is still breaking in. I will then change every 8k from now on which will be about yearly (or longer)
My latest Blackstone analysis is posted on Lance's thread.
I used the same oil on my LS430 and went 12k miles every change.
Old 07-14-15, 02:05 PM
4TehNguyen
4TehNguyen's Avatar
ran 3 vehicles to 10k on synthetic and all wear levels came back normal or even below the average. TBN tests showed around 10k was an optimum interval before the TBN hit 1.0. Changing synthetic at 3k or even 5k is a huge waste of money and time. I exclusively use synthetic in the family fleet now as it literally cuts my oil change labor in half.
Old 07-14-15, 04:16 PM
vbb
vbb's Avatar
I do approximately every 8K miles... or at least once a year (since my ISF is not my daily, I'm more likely to hit the year mark before the 8K mark these days).
I use Amsoil or Pennzoil Platinum synthetic.
But just listen to Lobux on this one (see the post he put up a few above mine). He's done all the testing and I'm comfortable with his findings and data on this and trust that way more than the old industry standard of "once every 3K miles" that was pushed a lot, especially during the 90s when I started driving. Heck, a lot of cars from the factory are recommending longer and longer intervals. Funny how that has become the new standard, especially now that more and more manufacturers and dealerships are offering free maintenance for a period of time on their newer vehicles.
Old 07-14-15, 05:19 PM
Sean
Sean's Avatar
I do mine every 7-8 months going by time rather than miles. I don't put a lot of miles on the car since I mainly work from home and have a short commute when on site but my driving is mostly city stop and go traffic. Maybe I could go longer and am overly concerned about my driving conditions decreasing the oil life?
Pennzoil Platinum, also. I've practically gotten it for free my last three oil changes.
Old 07-15-15, 06:57 AM
4TehNguyen
4TehNguyen's Avatar
if you want to be positive, send a sample in for testing. My guess is you will still be good even at 7-8 months
05RX330AWD
06-19-17 05:10 PM
giantdefy
02-07-10 10:59 PM
Jewcano
Maintenance
04-01-06 08:43 PM
RA40
08-24-04 12:16 AM
schtebie
Maintenance
14
02-26-03 11:40 AM
Quick Reply: Oil change intervals?
