Did a Full ISF CHECK UP SERVICE ~ HELP NEEDED
I had to put every 1 week like 500 ml of coolant
i did a check up on my ISF - 100,006 Mile
probably i have to change my water pump as i read here which most have problem with it and also the radiator fan motor needs to be changed
THE GUY told me something about " engine cover leak ~ center plate leak or engine block water ~ i really didnt got it that much or am not that good with the engines ~!!! is there anyone have any idea about it ? or i guess maybe its because of the water pump caused this ???
they are pro In Lexus this Garage ,,
he told me its a plate under the engine , we can fill with silicon if it can be !!
am kind of worried since he told me its under the engine ~ is this situation normal for doing this ?
Tech Info Resource
Check out this thread: https://www.clublexus.com/forums/is-...-slightly.html
It talks about the whole thing. It is unfortunately more common than anyone would like.
Thanks all for the reply
Yes after a water punp change,
Still the leak was there
I need to change the center plate or engine plate ..!!
Is it same as the Ls460 ?
Here we do not have alot of isF part
If anyone has the part number ill be thankful
Tech Info Resource
Check your PM.
chrisfan
IS F (2008-2014)
09-30-13 10:14 AM
