Front Brake issue
Old 06-30-15, 01:11 PM
ISFCOBRA
ISFCOBRA's Avatar
Default Front Brake issue
Need some guidance on this issue.
Front driver side brake squeals on a stop and release. this is the only side that produces this noise. Brake clearance is still very good and this noise has been off and on since i bought the car in December. Car has about 25k miles on it and will be replacing brakes at 30k.
Thoughts....
Old 06-30-15, 01:17 PM
Lmood
Lmood's Avatar
Is the shield in the back hitting anything?
Old 06-30-15, 01:20 PM
Vervish
Vervish's Avatar
I would pull out the pads, clean the the backing plates and add a little lube (to the backing plate).
Very easy to do with basic hand tools..
Old 06-30-15, 01:40 PM
ISFCOBRA
ISFCOBRA's Avatar
Thank you and i will check on that this weekend and clean up this side.
Old 06-30-15, 02:11 PM
F_Throttle
F_Throttle's Avatar
I have a similar sound going on and created a thread about it. Mine is in the Rear-Passenger. It is a higher-pitch squeaking.
The dealer's response: "Noise associated with High-Performance Brakes"
Old 06-30-15, 02:17 PM
j3ff
j3ff's Avatar
Seems normal. Our brakes with oem pads and rotors all seem to make some noise at some point; intermittent. I wouldn't worry about it. My brakes have good days and bad days .
Old 06-30-15, 02:56 PM
Rickna
Rickna's Avatar
I had some squeal as I would come to a stop with OEM pads & rotors. I replaced them with Centric rotors & Stop Tech pads-problem solved.
Old 06-30-15, 04:27 PM
SpeedFreaksUSA
Former Sponsor
SpeedFreaksUSA's Avatar
As others have mentioned this is common with some pad compounds including the OE IS-F compound. When you are ready to replace your pads with a new set we have a couple options that produce much lower levels of dust and are noise free without sacrificing the levels of performance you expect on the street. As always we have additional discounts available for members on here.
The two most popular options are:
Project Mu NS400 PS4F160 D1365 Lexus IS-F Front
Project Mu NS400 PS4R106 Lexus ISF IS-F Rear
Carbotech Performance Brakes, CT1365-1521 (Lexus IS-F Front)
Carbotech Performance Brakes, CT1366-1521 (Lexus IS-F Rear)
-Matt M.
Old 06-30-15, 04:58 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,079 Likes on 2,472 Posts
Unfortunately, I have Carbotech 1521 (Bobcat) in my front and they do the exact same thing. But I have been lazy and not bedded them in. I know they would be a whole lot better if I did.
Old 06-30-15, 05:47 PM
Vervish
Vervish's Avatar
My Stoptechs are quiet..
Old 06-30-15, 08:20 PM
ISFCOBRA
ISFCOBRA's Avatar
Thank you all....
Have a Happy 4th of July....
Old 06-30-15, 09:35 PM
flowrider
flowrider's Avatar
Received 1,943 Likes on 1,369 Posts
I am running Ferodo DS2500 Pads in front and stock pads in the rear. When I installed my pads I bedded them in properly. They have never made any kind of noise. IMHO, most quality (not full race) pads will be quiet if bedded in properly.
Lou
Old 06-30-15, 10:07 PM
I8ABMR
I8ABMR's Avatar
Odd. My car only makes that noise temporarily after it has rained and the brakes are drying. If it drives you nuts just replace them a little early and make sure to bed in the new set. Are you really hard on the brakes ??
Old 07-01-15, 09:11 AM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Originally Posted by I8ABMR
... Are you really hard on the brakes ??
He is not. The Lexus on the caliper is still silver. It turns gold when you get the brakes really hot.
Old 07-01-15, 03:00 PM
ISFCOBRA
ISFCOBRA's Avatar
i don't think i am hard on my brakes but have a heavy foot on the gas pedal.. LOL.
Quick Reply: Front Brake issue
