supercharger
Old 04-24-15, 04:41 PM
toyer14
toyer14's Avatar
Default supercharger
Has anyone been able to supercharge their isf?If yes what supercharger and how u do it? Figure if i soend 3k on headers why not just supercharge.
Thanks
Old 04-24-15, 06:36 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,845 Likes on 2,332 Posts
All who have tried have failed. Best of luck with that. If you succeed, you will have a monopoly.
Old 04-24-15, 06:44 PM
Meraki Autoworks
Your #1 Lexus Vendor
Meraki Autoworks's Avatar
3k on headers? What headers are you thinking of lol.
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Old 04-24-15, 07:56 PM
idoke1
idoke1's Avatar
^^He might wanted novel headers.....those are pricey. I remember seeing a prototype Greddy Supercharger here on the classifieds a while back. I remember the post concluded that it can boost 4 psi and any higher was on the buyer. Its been a while back so i don't remember too well. Perhaps someone here can dime in on that one.
Old 04-24-15, 08:58 PM
Justind27
Justind27's Avatar
Thought bout it, then saw the ttcperformance 3ur 7.0L stroker kit and figured that would be more fun seeing how either would require some sort of standalone ecu... Hell, something goes wrong on the f motor the thing cost more than the 3ur stroker kit alone..
Old 04-25-15, 12:45 AM
ISF4life
ISF4life's Avatar
Another rookie just joined the forum lolz :P
Old 04-25-15, 01:10 AM
RichFlair
RichFlair's Avatar
Let's just say in a nutshell intake, headers, catback, and nitrous (depending on what size jets you use) will get you in the neighborhood of 500whp. Now if you want to step outside the box by all means do so, it's your money. But just know that there has been those before you that have and not succeeded. Your biggest obstacle from what I've seen is tuning.
Old 04-25-15, 01:14 AM
RichFlair
RichFlair's Avatar
Come to think of it even if you were to have a functioning supercharger, wouldn't you want an upgraded exhaust system?
Old 04-27-15, 08:50 AM
hargo
hargo's Avatar
Your 100% right.. Tuning is everything.. Never going to happen..
Old 04-27-15, 11:23 AM
Fsport2UR
Fsport2UR's Avatar
Tuning is only one factor, and I wouldn't say is the main obstacle. The real problem lies with communication with all the ecu components and the source code needed to hack in to it to make changes. We have a auto/manual tranny with a very intelligent ecu controlling it; make changes to the main ecm(or swap in a standalone) and everything else will not work properly. While it may be possible to run some type of piggy back unit to simulate conditions, there is so much involved that it will throw a fit(everything is tied in to one another and not as independent as you would think). I believe there are 14 ecus in the ISF. While some software engineer maybe able to tap in to it, it is more than just making a couple changes, he would need to know the full spectrum of how everything works and ties in with one another. If he is that intelligent, I am pretty sure he would not be working as a tuner.
The only true solution to really modify our engine, you would need to pull everything luxury out of the car, including going with a different tranny. Run a stand alone that controls the engine only and bolt up a regular manual tranny. Manabu "Max" Orido is currently campaigning a Toyota 86(FRS) with a 2URGSE engine...it is running on a manual tranny and motec standalone. No one here on this board wants to tear up their ISF and take it to that level...which involves tossing all the luxury out of their car and going with a basic setup. Plus the money involved to make it happen.
Old 04-27-15, 11:30 AM
suprasupra
suprasupra's Avatar
I am happy with mine stock , There are way better platforms out there for modification. JMHO
Old 04-27-15, 12:39 PM
chris07is
chris07is's Avatar
jiggawho has the greddy, I think...
Old 04-27-15, 01:19 PM
PatrickISF
PatrickISF's Avatar
Pretty sure he took it off and placed it up for sale again.
Old 04-27-15, 02:19 PM
Justind27
Justind27's Avatar
3ur supercharged alone will make 500+, at some point I really believe I will mod the f the way supras n skylines are (swapped n built crazy) for now I'll just enjoy it for what I get from it. Definitely has been the funniest daily driven car I've had so far.
Old 04-27-15, 02:42 PM
Fsport2UR
Fsport2UR's Avatar
Swap in a supercharged 3UR and guaranteed nobody here is going to care since it is not the original 2UR engine. Just like the Ekanoo ISF, quite a few members here don't care or even associate it to our ISF, since it has a different engine and was just an ISF shell.
Quick Reply: supercharger
