My 1/4 mile result....pretty disappointed
Old 02-25-15, 10:15 PM
idoke1
idoke1's Avatar
Exclamation My 1/4 mile result....pretty disappointed
I just came back from sac raceway today and i'm pretty dissapointed. I only had one run during that night and i overreved the car 3 times and had a terrible launch. I was dissapointed on how bad the track prep was. Temperature was about 48 degrees F. I did a burn out to warm up my Stock potenzas. I didn't lower the air pressure. ..maybe i should had? There were tons of cars, mainly the new 13 and up mustang gt. I waited 1 hr before i could run. Had my engine properly warmed up as well during the sit. Anyway, here are my results.
Sorry for the lopsided pic. Its really not but it posted here lopsided.
Attached Thumbnails My 1/4 mile result....pretty disappointed-20150225_221308.jpg
Old 02-25-15, 10:18 PM
Bakewalk
Bakewalk's Avatar
http://www.dragtimes.com/da-density-...calculator.php
Density altitude calculator. It really makes a difference if you are in a high altitude area. I live in Alberta Canada and my density altitude is sometimes around 4500 ft. My 13.03 run last summer was actually a 12.56
And yes, remove lots of air from your tires, GRIP!!!
Old 02-25-15, 10:28 PM
Bakewalk
Bakewalk's Avatar
uh oh, you had prime conditions to race that night, here is what I got for you...
Stock and Mildly Modified Naturally Aspirated Engines
13.243 @ 108.614 MPH
Read more: http://www.dragtimes.com/da-density-...#ixzz3SpW6cgNC
Old 02-25-15, 11:25 PM
Meraki Autoworks
Your #1 Lexus Vendor
Meraki Autoworks's Avatar
time for full bolt ons, headers, exhaust, intake . jk it probably takes experience and getting used to the car, also get fatter tires.
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Old 02-26-15, 12:20 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,845 Likes on 2,332 Posts
This does not speak to track prep at all. Sac Raceway isn't always on top of this. I've been there a time or two.
Old 02-26-15, 01:00 AM
RichFlair
RichFlair's Avatar
Im sure you'll get a better ET with a bit more practice. I'm in norcal, if you want to hit the track again let me know.
Old 02-26-15, 05:09 AM
MRxSLAYx
MRxSLAYx's Avatar
Its easy to see the top times and think that every track is created equal... This is definitely not the case so i wouldn't be too disappointed. Im pretty sure that most of the cali guys are close to your time anyways
Old 02-26-15, 06:44 AM
idoke1
idoke1's Avatar
^^Thanks you guys. I may go back on a test and tune where the track is supposedly prep alot better. I was mainly dissapointed in my launch and 60 foot times. I decided not to brake torque as i saw lots if other cars wheel hopping of the line. On green, I did mash the gas about 90% and just as i expected, i was wheel hopping too. That lead me to conclusion that the track was prep poorly.
Old 02-26-15, 07:12 AM
specie
specie's Avatar
No burnout on street tires.
Old 02-26-15, 08:40 AM
RSXiMUS
RSXiMUS's Avatar
Hey 13.1 isn't so bad for one run only, considering your 60ft time, wheel hoppin off the line plus you hitting the rev limiter 3 times in a bone stock IS-F?.. I'd say that's pretty good.
Your trap seems a bit low though.
Old 02-26-15, 09:01 AM
Gymkata
Gymkata's Avatar
13.1 isn't bad at all for only 1 run, especially if track conditions were suboptimal. I don't know what your stock tires are capable of, but with a solid launch you can knock .25 seconds off that 60' time.
Old 02-26-15, 11:41 AM
F_Throttle
F_Throttle's Avatar
Do you guys keep it in Auto? I can't find it, but I read that auto was quicker.
Old 02-26-15, 12:32 PM
BS ISF
BS ISF's Avatar
always have all nannies turned off, sport button on and in manual mode shifting after the beep.
Old 02-26-15, 12:33 PM
Gymkata
Gymkata's Avatar
The quickest is manual mode, disable traction and stability control (long push), launch at 800-1200 rpm (really depends on your power and traction), shift at or just after the beep.
People have differing opinions on when exactly to shift, but my fastest 1/4 mile was done when I shifted a split second before the beep in first and just after the beep in 2-4th...crossing the 1/4 mile bouncing off the rev limiter in 4th.
Old 03-02-15, 09:03 PM
Ltaboso
Ltaboso's Avatar
speaking if the tire pressure for drag races...what is the best pressure to put? 25psi On 275/30 rear tires?
Sport+manual mode?
Quick Reply: My 1/4 mile result....pretty disappointed
