Brembo "Coated" Rotors
Old 02-24-15, 07:56 PM
BieberNutz
BieberNutz's Avatar
Default Brembo "Coated" Rotors
I searched on these key words and wasn't able to find anything specific to my question which is this...are
these rotors these rotors
direct OEM replacements or are they some sort of knock-off that are using the right key-words? Same rotors found http://www.partsgeek.com/catalog/2008/lexus/is_f/brake/brake_rotor.html and I'm just curious what is meant by "Brembo Brake Disc Coated" since there seems to be emphasis on it? Sorry if this has already been covered and I couldn't find it but I assure you I did search. Thanks in advance.
Old 02-25-15, 06:06 PM
Rickna
Rickna's Avatar
I searched around and there are other vendors sell the same Name & part #. On Brembo's site there is no such number. In fact, it's a completely different type of number.Non alpha-numeric, etc.
http://brembo.mycarparts.net/
Old 02-26-15, 06:20 AM
Justind27
Justind27's Avatar
I previously bought cheaper aftermarket rotors, just installed figs/rb rotors yesterday with stoptech pads that we're already installed with stoptech lines and fluid. What a tremendous difference!
Old 02-26-15, 09:53 AM
WhyTheF
WhyTheF's Avatar
I'm not sure of that p/n on Parts Geek but I believe the "Coated" term is referring to UV coated rotors. The description can be found on Brembo's website here: http://www.bremboparts.com/us/produc...v-coated-discs
Click on "Catalogue" to find the Brembo p/n.
I know this because I recently purchased a set for the rear and found the p/n on Brembo's site
Old 02-26-15, 05:59 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,835 Likes on 2,324 Posts
I'd like to see the same rotors after a weekend on the F at Carolina Motorsports Park.
Old 02-26-15, 06:50 PM
BieberNutz
BieberNutz's Avatar
So I'm guessing based on the responses so far this is a case of "too good to be true" and these are NOT direct OEM replacements???
Old 02-26-15, 07:30 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
I am sure they are mechanically sound and a perfect fit, but they are not finished the same as the OEM rotors.
vscout
Suspension and Brakes
12
07-18-15 11:23 AM
huksa
IS F (2008-2014)
09-11-12 12:13 AM
lkapimp216
11-11-09 01:20 AM
lx470man
11-14-04 10:21 PM
spxChrome
02-28-03 05:59 AM
Quick Reply: Brembo "Coated" Rotors
