Bc coilover help
Old 02-23-15, 06:52 AM
MyisFly
MyisFly's Avatar
Default Bc coilover help
I have 16/12 spring rate i suppose so thats what i requested anyway been rolling for about a year in dallas this is without the swift spring upgrade. My ride seems to be getting more and more bouncy i have played with the damper adjustments like crazy but sometimes cant tell the difference should i turn towards hard or soft to get less bounce seems to bounce to me either way HELP.
Old 02-23-15, 07:26 AM
yjk1975
yjk1975's Avatar
I have had to clicker firmer to get rid of the bounce. But I think the BC coilover system are just not that great.
Old 02-23-15, 08:16 AM
MyisFly
MyisFly's Avatar
I was starting to think the same thing went the cheap route starting to regret it now
Old 02-23-15, 10:07 AM
digger08
digger08's Avatar
I follow figs recommendations of adjustment for track and city use
9 clicks out on the front shocks and 12 clicks out on the rear provided an excellent canyon/track setting while a more conservative
20 clicks FR and 25 clicks RR was a more suitable ride for a daily driver.
...and they are perfectly fine after 2 years.
Make sure you are adjusting from the bottom setting up and not from the top setting down.
Digger08
Old 02-23-15, 10:54 AM
yjk1975
yjk1975's Avatar
I have messed with the settings enough. I should not have gone cheap and just went for the KW V3s.
Old 02-23-15, 11:08 AM
MyisFly
MyisFly's Avatar
I second that bruh
Old 02-23-15, 04:05 PM
Reaper21
Reaper21's Avatar
They're really not bad coils at all for the price. If you're not tracking these will do just fine. I decided to spend the $1500 I saved from the KWs on a JoeZ exhaust.
Old 02-23-15, 08:02 PM
yjk1975
yjk1975's Avatar
The thing is, coilovers matter. Its something that you notice every time you get in the car. I knew I was making a mistake when I went cheap. Its a ISF not a 350z.
Old 02-24-15, 11:03 AM
kbnttrthg2
kbnttrthg2's Avatar
Default Pre Load
Check it. Make sure it's set to the correct specs. I have a bit of experience with BC and that seems to be the issue about 90% of time.
Just picked up my IS F this past Friday and I love it! Looking forward to all the knowledge of the platform here.
-KB
aEO 37
Suspension and Brakes
20
06-16-17 06:56 PM
booey23
05-04-16 05:52 PM
ATP
07-16-15 11:33 PM
kim0217
17
05-28-12 07:09 PM
mdgrwl
26
11-19-11 05:17 PM
Quick Reply: Bc coilover help
