Sikky header heatshield bolt problem
Old 08-25-14, 09:33 AM
LexusISF19
LexusISF19's Avatar
Default Sikky header heatshield bolt problem
Hi i was wondering if anyone has a solution for this heatshield bolt rubbing on the header ? Thx
Attached Thumbnails Sikky header heatshield bolt problem-image-720045482.jpg   Sikky header heatshield bolt problem-image-2216428444.jpg
Old 08-25-14, 09:41 AM
Mrd916
Mrd916's Avatar
My friend Bret had this same problem and Lexus of Tampa found a way around it with no issues during his header install. PM him at MYISF, I think he is still active but he traded his car in for a Porsche.
Old 08-25-14, 11:14 AM
LexusISF19
LexusISF19's Avatar
thanks bro
Old 08-25-14, 12:46 PM
Lexura1414
Lexura1414's Avatar
I have the same problem. My tech at Lexus tried to file it down but to no avail. Sikky will replace the side affected but I just don't have the time and patience to have it pulled out, sent to Sikky and then installed back in. I will just sell or trade in my car with it.
Old 01-29-15, 12:47 PM
abohler
abohler's Avatar
Does it cause a rattling sound when you drive and get on it?
Old 01-29-15, 07:45 PM
Lexura1414
Lexura1414's Avatar
The rattle is heard when turning left.
Old 01-30-15, 12:16 PM
BS ISF
BS ISF's Avatar
^^^^this!!
Old 01-30-15, 03:28 PM
darbs242
darbs242's Avatar
Have them installed at JE for a perfect install every time
Old 01-30-15, 05:14 PM
etohprn247
etohprn247's Avatar
I see this flaw overtime the bolt will grind a small hole into the header, hopefully this issue will be fixed? I'm still saving for a Sikky setup too )))
Old 01-30-15, 05:23 PM
melbitoast
melbitoast's Avatar
Lots of us have this issue. The general sentiment is that the bolt is unnecessary to hold the shield in place, and you can have it removed. Problem is, removing it by normal method requires dropping the engine, which is a multi-hour job. I'm going to have it removed when I get my motor mounts replaced.
Old 01-30-15, 09:30 PM
RedlineAZ
RedlineAZ's Avatar
I could be wrong but I'm pretty sure you don't need that heat shield there
Old 01-30-15, 10:50 PM
ct200
ct200's Avatar
I had the same problem on mine!! just removed the bolt and problem was solved...
Old 01-31-15, 11:58 AM
etohprn247
etohprn247's Avatar
can this install be done at home with decent tools...no lift etc? Moderate knowledge of cars. Or a lift is definately needed?
Old 01-31-15, 02:42 PM
abohler
abohler's Avatar
When you feel the rattle turning do any of you guys feel it in the steering wheel. Like does it feel like the steering linkage is rubbing on anything?
Old 01-31-15, 10:08 PM
melbitoast
melbitoast's Avatar
I don't feel the rattle. Just hear it.
Quick Reply: Sikky header heatshield bolt problem
