What is the one step colder plug for the isf?
Old 08-23-14, 09:39 PM
KOKISF
KOKISF's Avatar
Default What is the one step colder plug for the isf?
Like I state up there whats the one step colder plug for the isf, ive heard denso irridium ikh 22 and the two step colder is the ikh 24 can anyone confirm?
Old 08-24-14, 03:07 PM
abohler
abohler's Avatar
I am in the process of doing this right now. The ISF plug is -5. Going one colder would be -6, if you are running a lot of nitrous or something I may even suggest -7, but the idle will be a little more rough.
Old 08-24-14, 07:12 PM
shyguyF
shyguyF's Avatar
The oem ISF spark plugs are 20 in heat range so one step colder is 22, two steps are 24.
Denso they use scale 14 16 ........20 22 24... in heat range for their spark plugs.
NGK they use scale 4 5 6.....7 8 9....in heat range for their spark plugs.
I'm running IKH20 plugs for my F but not recommended for our engine. but not problem to mine so far.
Old 08-25-14, 07:56 AM
tgui
tgui's Avatar
Are you doing something that makes combustion that much hotter on average? On turbo cars with big turbos colder plugs can help fight predetonation, but thats because you're heating up the cyl that much more. Colder plugs on a stock-ish engine I'm guessing might do nothing... to hurting performance, but thats just a guess.
Old 08-25-14, 06:46 PM
KOKISF
KOKISF's Avatar
So denso is not recomended for the F ? Im spraying bro!
Old 08-25-14, 07:03 PM
KOKISF
KOKISF's Avatar
Still no one has the correct spark plug number for a one step colder plug for the oen ngk plug?
Old 08-25-14, 09:49 PM
shyguyF
shyguyF's Avatar
I do not say Denso not recommended for the F b/c OEM spark plugs for ISF is Denso FK20HBR11. If you really want one step colder spark plugs you can pick Denso IKH22 ( iridium power ).
itsmike177
IS F (2008-2014)
92
02-24-23 12:25 PM
newguy1354
IS F (2008-2014)
29
03-29-20 07:09 PM
Scott610
05-30-17 07:47 PM
fathorsejr
02-10-16 08:43 AM
abohler
IS F (2008-2014)
06-09-14 12:50 PM
Quick Reply: What is the one step colder plug for the isf?
