JOEZ PTS exhaust
Old 08-10-14, 07:45 AM
dabs
dabs's Avatar
Default JOEZ PTS exhaust
Any tips on the install please?
Also, I can't understand why my pipes are not polished?
The website says that the back pipes are polished....
Old 08-10-14, 08:20 AM
Weapon F
Weapon F's Avatar
Its hard to see anything from picture you posted but from what I can tell they seem to have shine. The mufflers will be highly polished everything else stainless steel from what I can see they look right to me. Just to let you know I have Joe Z PTS exhaust.
Old 08-10-14, 08:27 AM
4TehNguyen
4TehNguyen's Avatar
installing exhaust system pretty straight forward. Use WD40 or something similar to remove the rubber hangers, makes it a lot easier. A friend helps too since the parts are bulky. Youll need a O2 sensor removal socket to take off the O2 sensors. Do not let the O2 sensor wires to twist tight when you install them. Youll want to start disassembling exhaust from the mufflers going to front, and then install new parts from front to back. Make sure all bolts are tight with no leaks.
Mufflers are polished but the rest of the system and piping is just stainless. This is one for the new IS
Old 08-10-14, 08:43 AM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
New for 2014 all the pipes are now finished in Brushed 304 Stainless Steel...
In the hardware bag, there are some basic install tips..
I will say this is not for the novice..
Glad to see the system made it to South Africa safely
Enjoy,
Joe Z
Old 08-10-14, 08:53 AM
jat0223
jat0223's Avatar
Use silicone spray for the rubber hangers instead of WD40. WD40 is corrosive to rubber.
Old 08-10-14, 10:12 AM
dabs
dabs's Avatar
Thanks for the input guys. Im really anxious to get this installed and terrorise the streets.
Joe, i was really looking forward to those polished pipes. What was the reason for the change?
Can i get it polished myself?
Old 08-10-14, 10:38 AM
4TehNguyen
4TehNguyen's Avatar
WD40 website says its fine for rubber.
Old 08-10-14, 10:51 AM
Joe Z
Joe Z's Avatar
Lightbulb
Sure if you have a good Polisher in town..
Over time we saw that the Brushed finished had better visual appeal maintenance wise, compared to the polished finished.
Joe Z
Old 08-10-14, 11:36 AM
I8ABMR
I8ABMR's Avatar
great system. I took a ride in an ISF with a Joe Z recently and its a great system. Nice deep tone and quiet when cruising on the freeway
Old 08-10-14, 11:38 AM
4TehNguyen
4TehNguyen's Avatar
another tip is before you fire the car up, wipe down all the surfaces of grease and grime, it may burn in and brown the finish if you dont
Old 08-10-14, 04:45 PM
I8ABMR
I8ABMR's Avatar
Not sure it even matters that its polished. Its like polishing the bottom of your shoes.
Old 08-10-14, 04:51 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,842 Likes on 2,330 Posts
I use dish soap diluted about 25/75 with water. Works fine and rinses off the metal and the rubber with no lasting impact.
cremaster
IS F (2008-2014)
15
06-14-12 08:14 PM
LDYNRED
Performance
63
05-02-12 07:20 AM
tomkirklan
IS F (2008-2014)
01-15-12 08:33 PM
lx470man
17
03-26-09 02:02 PM
combfilter
10-03-07 02:09 PM
Quick Reply: JOEZ PTS exhaust
