DIY Repainted calipers from blue to burnt copper on my USB IS-F
Old 11-30-14, 10:09 AM
  #31
Weapon F
Weapon F's Avatar
Originally Posted by Sylvan
Is it VHT burnt copper? I had some Honda inca pearl mixed up hoping it is close to the Brembo gold but I think it looks more like a light gold as opposed to the Orange gold that brembo uses
Yes it is I also used VHT high heat Primer and Clear Basically here were my steps
1.strip off old paint
2.degrease and neutralize stripper
3.apply primer
3.apply paint
4.apply high heat Vinyl brembo decal
5.apply clear coat
Old 11-30-14, 10:33 AM
  #32
I8ABMR
I8ABMR's Avatar
NICE !! I think RedlineAZ was going to do the same color. Looks great and would probably work on any color.
Old 12-02-14, 10:13 AM
  #33
Gearbangin
Gearbangin's Avatar
Did mine in blue.
Old 12-02-14, 05:53 PM
  #34
speeddem0n
speeddem0n's Avatar
Great change over. Im scared to mess up the original black finish on my calipers especially because i have brand new ones on the fronts, otherwise id go crazy with it and experiment with different ones.
Old 12-02-14, 06:06 PM
  #35
Rickna
Rickna's Avatar
This thread has inspired me for another winter project.
Old 12-02-14, 06:22 PM
  #36
v8sedan
v8sedan's Avatar
Winter project here too, good job
Old 12-02-14, 09:50 PM
  #37
jspecvtec7
jspecvtec7's Avatar
wow nice job it looks great
Old 12-03-14, 01:40 AM
  #38
TRACKMKIII
TRACKMKIII's Avatar
Looks great!! Hard to believe that finish came out of a spray can!!
Old 12-03-14, 02:03 PM
  #39
Weapon F
Weapon F's Avatar
Good deal, love winter projects something to look forward to during cold winter months.
Old 12-03-14, 03:42 PM
  #40
Weapon F
Weapon F's Avatar
Thanks guy's and yes you can achieve great results with rattle can if you take your time and prep properly it's all about prep, the actual painting takes know time at all compared to preparing everything properly. If done properly and if you keep the calipers are cleaned on a regular basis the paint job should last for several years with no problem.
Old 03-07-16, 06:58 AM
  #41
Diesel350
Diesel350's Avatar
3.apply primer
3.apply paint
5.apply clear coat
So you didn't have to sand the caliper at all?
Old 03-07-16, 10:43 AM
  #42
Bigjon3475
Bigjon3475's Avatar
Post:
https://www.clublexus.com/forums/is-...ml#post8663932
Old 03-07-16, 09:40 PM
  #43
I8ABMR
I8ABMR's Avatar
Looks really nice. In the end I think this would be a great color for the MRM Fs as well. I dig.
Old 03-08-16, 12:52 PM
  #44
F LIFE
F LIFE's Avatar
I would highly recommend spending no time taping everything off and spend that same amount of time removing the caliper. It's pretty simple to do and you'll be able to paint is easier and better.
Old 03-08-16, 02:07 PM
  #45
ISFLexy
ISFLexy's Avatar
Depends on what someone is more comfortable doing, taking time to tape, or taking time to bleed the brakes and deal with brake fluid...
Quick Reply: DIY Repainted calipers from blue to burnt copper on my USB IS-F
