Cell phone mount recommendations
#61
I just got this one to replace a similar one that had a broken vent clip. At $14 via Amazon.com, I think it's a great deal if you want a vent mounted phone cradle.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It's very similar to my old one, but a little better. It's plenty secure for street use & should be OK for the track too.. If not, I can add a couple small zip-ties like I did for my old one at the last Pocono event. The big difference from my old one is the swivel connector.. I think that's a plus since I can angle phone toward me on the street, then make it perpendicular to the dash at the track to ensure GPS apps like Harry's Lap Timer are as accurate as possible.
-Mike
-Mike
-Mike
#62
-Mike
-Mike
#63
Tech Info Resource
https://www.amazon.com/dp/B00UXS7958...oding=UTF8&me=
Bought this a couple of weeks back to replace the lighter mount unit. The USB power on it failed, so the phone would not charge. It's mounted on the dash similar to the video, and provides wireless charging natively. I bought a high wattage adapter to plug the power in, and it keeps the phone charging - stable at 100% even when running Google maps. I just need to do something less intrusive with the power wire. I will update with a pic when it is light outside.
#64
That looks like a Kuda mount-
http://www.kudausa.com/kuda-custom-l...exus-k321.html
#67
^^^^Yes, the Kuda has a flat face. An additional part is needed to mount the phone. I bought this:
http://www.kudausa.com/universal-pas...-pda-a856.html
Lou
Lou
#68
This one works amazingly for me and is only $8. I bought my GF and sister one also. Magnet slides in between the phone/case and no attaching needed. Literally hold the phone up to it and it grabs it tight. Unless you're going offloading or autoxing with lots of very tight turns, it'll hold strong.
https://www.amazon.com/gp/product/B00PGJWYJ0/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
#69
Lou
Lou
cha7Li3 (03-21-17)
#71
#73
Cigarette lighter mount works great between shifter and stereo controls. That way zero damage is done to your interior. No blocked vents etc. Can reach screen with hand on the shift ****.
#74
Any update on the phone mounts? Anything new someone's discovered to work well with our cars?
I'm looking for a minimalistic look that would work well for Uber/Lyft and for personal use...
I know that ProClip has the minimalist idea going for it, but the automatic transmission mount is just way out there on the opposite side. Anyone tried the manual transmission model for an automatic? If the only thing it blocks is the lettering for "P, N, S", then that isn't really a problem for me.
https://www.proclipusa.com/product/8...-console-mount
Any tips? Any mounts you've discovered that work well with our cars?
#75
Sorry not the best pic but ive gone through several from mounts that fit in from the CD slot (not bad but through vibration works itself loose over time and blocks a bit of my screen). Also used the traditional air con vents but as ours are so high, i hated it having to extend the arm that high up to use it and again it blocks the screen so im now using this.
Can be mounted via air con vent but has a base to fit on the centre console near the gear selector (rock solid, not going anywhere). Its just in the right positon so i can open the small spring loaded cup holder section but can move into R and other gears no issue. If i want to drive manual, i use the paddles anyway so no big deal. Its also a wireless magnetic charger so atleast its charging everytime i get in the car and i use my Vline to power it via USB. Also can swivel etc so i can basically have it angled facing me, close to use etc. I have a note 8 so its not a small phone but still works no issue and the phone has never come loose, fallen etc whilst driving
Been using it for a month or so and its my preferred phone mount to date
