Osram D4S CBI
Old 09-30-14, 01:07 PM
  #31
RMA
RMA's Avatar
Originally Posted by shyguyF
Congrats ! Did you use the code ? I did and save 37 bucks from TRS.
I did $151 shipped I take it these are an easy pop in ?
Old 10-07-14, 09:23 AM
  #32
RMA
RMA's Avatar
I have a tech about to install the bulbs. What is the easiest way to access the headlights for bulb install ?
Old 10-07-14, 09:30 AM
  #33
Reaper21
Reaper21's Avatar
Take the bumper off and take the headlights out. Easy peezy.
Old 10-07-14, 09:43 AM
  #34
Evil Teo
Evil Teo's Avatar
No dont take the bumper off. Just pop the engine hood open. Follow the directions from the 2is section diy for swapping bulbs.
Old 10-07-14, 09:47 AM
  #35
Evil Teo
Evil Teo's Avatar
https://www.clublexus.com/forums/is-second-generation/192254-aftermarket-hid-installation-with-pictures.html
Look at thr pictures. You dont have to drill holes but use it as reference. The place where the bulb is identical to where our is located. Good luck.
Old 10-07-14, 10:45 AM
  #36
T4styPh0
T4styPh0's Avatar
On the ISF, there's no need to take anything apart except for the washer fluid filler neck on the driver side, that's it. Should be plenty enough room to stick your hand in there and pop open the caps.
Old 10-07-14, 06:21 PM
  #37
9aristo
9aristo's Avatar
there's an easier and peezier way.
unless removing the intake box and washer fluid tube is harder than removing the entire bumper, than i', wrong.
Old 10-07-14, 07:33 PM
  #38
JDMV8
JDMV8's Avatar
Unscrew intake box (two 10mm bolts I believe)
Have someone lift the box for you (no need to completely take off the intake, but you can undo the intake elbow from the box), and you can access passenger side bulb. use a flathead to pop open the metal "gate" and voila, bulb is there.
For driver side, simply unscrew one 10mm bolt on washer fluid cap, and pop the plastic tube and cap up.
You will be able to access bulb easily now (with some wire moving).
Changing both of my low beam bulbs took me about 25min, and that's with reinstalling the intake box and engine covers.
Good luck!
Old 10-08-14, 06:23 AM
  #39
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,078 Likes on 2,471 Posts
I did this^^ after I started having issues with one of my bulbs being intermittent. It's pretty easy.
I bought Philips bulbs. Same exact bulb as OEM, and paid far less than half what these Osrams cost.
Old 09-06-16, 06:24 AM
  #40
FFM
FFM's Avatar
I am a little disappointed with the factory output of my 2011 headlights. Thinking about these bulbs, and potentially a clear lens upgrade if it will yield me better results. Anyone done both the bulbs and lenses?
Old 09-06-16, 10:44 AM
  #41
T4styPh0
T4styPh0's Avatar
I got these bulbs awhile back and clear lens swapped about 2 week after. With the lens swap, the white was more crisp and so was the cutoff which also added a little bit more color to it. To me, it did make driving a night a little better but it isn't a full retro so just don't expect it to be super wide or crazy cutoffs. I will take a few pics later tonight.
Old 09-06-16, 11:30 AM
  #42
FFM
FFM's Avatar
Cool, thanks.
I did a retro on my Volvo through Matt @ TRS and looked great. Hard to compare to stock since it was vastly superior. My wife's C300 with the lighting package is leaps and bounds better than this car, which is a bummer. Exploring options to get some better output. I feel like the adjustment is off too, need to verify they are aimed properly too.
Old 09-06-16, 11:35 AM
  #43
liquidtek
liquidtek's Avatar
I've considered doing the clear lens swap but it's not high on my priority. Switching between my S2000 and my ISF it still blows my mind how crappy the headlight output is on this car. If the 2012 headlights weren't so expensive I'd consider retroing some non crappy projectors in there.
Old 09-07-16, 08:32 AM
  #44
PatrickISF
PatrickISF's Avatar
I agree with you on this. The headlights in this car are bottom of the barrel compared to the projectors in the S2000. I know, I owned an S2000 as well and the lighting was incredible in that car. I'd almost want to retro the S2000 projectors in this car but I just can't justify ripping apart the headlight to do it.
Old 09-07-16, 10:00 AM
  #45
mahcah
mahcah's Avatar
The reason for poor output is due to its design. See post #15 of the link below.
https://www.clublexus.com/forums/is-...-complete.html
Quick Reply: Osram D4S CBI
