air bag light
Old 06-27-14, 11:19 AM
imp0rted1
imp0rted1's Avatar
i'll have to print out the invoice from the dealer.. it was something like $1200 otd
Old 06-27-14, 11:34 AM
ISFWes
ISFWes's Avatar
Default Air Bag Light
I had the Air Bag light on my 2007 RX. It was the drivers side pilar air bag.
Lexus paid the 1200 for the replacement. It was covered under the 60K powertrain factory warranty.
Old 06-27-14, 12:00 PM
FNSSESPORT
FNSSESPORT's Avatar
My 2008 had the same issue, but I hadn't purchased it yet so the dealer had to fix it before I took possession. It took about two weeks to fix because apparently the part (it was a wiring harness) had to be shipped directly from Japan.
Old 06-27-14, 03:41 PM
imp0rted1
imp0rted1's Avatar
ok. i looked at my receipt
"instrument harness has intermittent open circuit front driver side knee air bag"
harness p/n 82141-53540 $1950
Labor $630
Old 06-28-14, 09:27 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,842 Likes on 2,330 Posts
Originally Posted by amgone75
I just looked ut up. Its a lsb addressing this issue. It affected mostly 250s and 350s but my ISF was also affected. Dealer replaced mine under warranty.L-SB-0167-08. Theres was a faulty harness going to the drivers knee squib.
IS-F is not included in this LSB. Only 250/350. They may have performed this procedure, but the LSB isn't showing any IS-F affected. There are no SRS LSBs for the IS-F in TIS.
I bet the problem is a pin in a connector. Lexus/Toyota/Scion all replace the entire harness even when there is a minor issue like this. My Supra had a cold weather issue with the +5v from the ECM to the throttle position sensors and the manifold pressure sensor. It lit up DTCs like a Christmas tree any time I let it get below 45F and fully cold soak. The problem was, it would go away within 10 minutes of operation. It ended up being the pin in the connector to the ECM. I removed the pin, tweaked the petal inside the pin ever so slightly, and it has worked fine ever since. I bet this problem is the same kind of issue. The crimping machine got a little to tight on the run of these harnesses so it only makes intermittent contact on a few cars.
I've had seat belts replaced in 10 year old cars under warranty because they are a fundamental safety item, and they were defective. I don't think it would be difficult to raise a reasonable question about your personal safety (if you believe airbags are not worthless and dangerous as I do) with the service manager and ask the hard question - If I get in an accident with my car, am I still safe? If I'm not, and this is a Federally mandated item in the car, why won't you fix it regardless of my bumper to bumper warranty coverage. This should be more like your emissions warranty...
Old 07-01-14, 11:40 AM
ddcruise
ddcruise's Avatar
car is still at the dealer day 8 and counting
Old 07-07-14, 10:54 AM
ddcruise
ddcruise's Avatar
they said it was a wire harness that was bad, had to order part
Old 07-07-14, 12:50 PM
mrkim
Banned
mrkim's Avatar
WOW.... tell the folks the dealer "HEY YOU BETTER NOT STICK ME WITH SOME IS250, BETTER LOAN ME A RC F damnit... I NEED THE POWER THE FUN..."
Old 07-08-14, 07:44 AM
ddcruise
ddcruise's Avatar
lol yeah they gave me a is250...................
Old 07-08-14, 12:28 PM
mrkim
Banned
mrkim's Avatar
aww man sucks huh? they stuck me with an is250 when I had to bring in my wife's is350 for those recalls... I should have opt for the hybrid... lol
DUDE its not too late JUST GET THE HYBRID!!! while you give them hell about having your car in the shop for such a long time.
Old 07-10-14, 09:49 AM
chris6878
chris6878's Avatar
My light has come on a few times. each time it was because of a connection under seat loose. usually after my car stereo was worked on.
Old 07-16-14, 09:23 AM
ddcruise
ddcruise's Avatar
part is in and lex is back at the shop 3 days and counting
Old 07-25-14, 08:19 AM
Bigcloud
Bigcloud's Avatar
My car is at the dealer now for this same issue. This is the second time it is there for the airbag light. The first time I was there it was a month out of the power train warranty. I have asked Lexus NA to help with a "good faith" repair. I was quoted $3400 to fix it!!
handy28
RX - 3rd Gen (2010-2015)
01-15-19 01:28 PM
ohiois350
02-13-18 07:12 PM
mikobangz
11-14-14 07:52 AM
amruss24
07-19-12 02:00 PM
xanthax
01-15-10 12:42 PM
Quick Reply: air bag light
