How bad is the oem Exhaust Manifold design?
Has anyone decatted or gutted the cats on the stock IS-F headers? I'm really curious as to how restrictive the cats are on the headers or if the runner design is just that bad. Something is a miss if Sikky and PPE can easily achieve a 30+ whp output.
Just wondering if anyone has looked into it further besides buying an aftermarket option?
I have both Sikky headers and a spare set of oem headers that I had jet-hoat coated in case I added a nitrous setup. Trying to decide if it makes more sense to just install the oem headers (and gut the cats) with the realization nitrous is in my future.
I was just reading up on past Nitrous threads and it got me thinking about the runners seeing that aftermarket headers pose issues on a high shot whereas the stocks seem OK. If the stock runners are decent enough to flow with NOS the cats have to be the real bottleneck perhaps?
I'm in a position right now where I can swap my stock manifolds in pretty easily or keep the Sikkys...not sure what I'm going to do.
This all started discussing Exhaust MANIFOLDS and the Main/Primary cats removal. Not sure why we are talking secondary cats as the information is clearly out there.
I'm assuming no one really knows the answer to the original question and the gains are likely greater just going with a Sikky or PPE header. However, on a high nitrous shot aftermarket headers prove deficient vs the stock manifold runner design. A decatted stock manifold could prove to be a better choice for those of us running or considering a nitrous setup.
Will the car pass a smog test with secondary cats out ?? Are these exhausts for "off road use" only . Many members have exhausts and we have cars that are now 5-6 years old. Im sure some had to go through smog
Any o2 sim should correct the CEL just as if a pair of sikky or ppe catless headers were installed.
It's pretty easy to DECat any header catalytic converter even on the vehicle. I've seen it done many years ago with a pry bar and torch.
I have a set of oem headers that have been jethot coated:
OMG you guys are Hardcore Ballers or your a train mechanic ....With CEL issues and having to drop half or part of engine to install/modify primary cats etc.( in our ISF specifically) and if issues arrive or reselling, yall just pay another $1k to reinstall headers back to stock? Mikelucci...did you remove catalytic converters just to jetcoat them, man that's a lot of work ;P
