Toyo Proxes T1 Sport tires
Old 04-04-14, 01:58 PM
BS ISF
BS ISF's Avatar
was going to go that route but I got all four for under a grand at onlinetires.com
pretty damn good deal and I wanted a softer compound tire.
Old 04-04-14, 04:27 PM
2012ISF
2012ISF's Avatar
I've been staying true to the oem bridgestone potenza's on my 2012. Can anyone comment on these please.
Old 04-04-14, 05:26 PM
VicTornin
VicTornin's Avatar
RE11 are a good choice too..
Old 04-04-14, 09:57 PM
itsmike177
itsmike177's Avatar
The OEM Potenza's that came with the ISF is an awesome tire. I would put them above the PSS (and PS2's that came on some ISFs) for all out performance on the dry track.
Just the Potenza's are expensive for the wear rating and wet weather traction isn't that good. PSS' are a very good all around performer, ie track + good wear rating + wet weather + relatively low cost.
Old 04-04-14, 11:08 PM
Meraki Autoworks
Your #1 Lexus Vendor
CL Vendor - Starter
Meraki Autoworks's Avatar
Originally Posted by itsmike177
The OEM Potenza's that came with the ISF is an awesome tire. I would put them above the PSS (and PS2's that came on some ISFs) for all out performance on the dry track. Just the Potenza's are expensive for the wear rating and wet weather traction isn't that good. PSS' are a very good all around performer, ie track + good wear rating + wet weather + relatively low cost.
No way.. PSS are better .. I think. I hated my potenzas
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Old 04-05-14, 08:09 AM
BS ISF
BS ISF's Avatar
What? PSS are about as expensive as you can go and are the highest rated in it's category.
Old 04-05-14, 08:58 AM
itsmike177
itsmike177's Avatar
OEM Potenza RE050A's (and OEM PS2's) made specifically for the ISF are over $300 each. PSS' are ~$250 each. As stated previously, "relatively low cost" especially for the performance PSS offers.
There is also the ~$170-200/tire range, but then are sacrificing performance. I have ran those sub $200 tires (Hankook Ventus v12 k110 evo, Continental DWS, Kumho SPT) and they make the car less enjoyable as all of them squirm under hard driving.
Old 04-05-14, 10:26 AM
BS ISF
BS ISF's Avatar
Damn I had no idea the oem's were that much!
Old 04-06-14, 06:05 AM
MYISF
MYISF's Avatar
WOW! Great discussion as usual from the CL ISF population...thanks.
I have gone back to my wheel guy and along with us trying to make a non-staggered setup work on my ISF I have also decided to go with the PSS. On the non-staggered setup, I am not going to compromise the car to make it work. Meaning I don't want to use spacers or have any daily rubbing issues. My wheel guy is really working with me to figure out my options (wheels, tires, etc...) that may work with that set up. For instance we have ordered a wheel 19x9.5 +38 (but no tires) so we can test fitment for the wheel first (brake clearance, etc...) before I incurr tire prices, shipping, etc... Once we find a wheel that works (non-staggered) or "not"...then we will order my PSS in the size we need...this is a process but I am trying to go with a setup that has a certain look but without compromising the car...wish me luck!
Old 04-06-14, 10:31 AM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,080 Likes on 2,472 Posts
If you are running the same offsets front and rear, you will be compromising mechanical performance. Any time you change the position of the wheel centerline from design spec, you change the suspension's performance.
Without doing a lot of other homework, you'll need to hope for the best and determine the results by trial and error. I truly wish you the best of luck, I'd like to run a square setup too, but I haven't put the time into measuring the chassis (I really should do this...)
Old 04-06-14, 10:47 AM
MYISF
MYISF's Avatar
Thanks...I figured if I got a non-staggered set up to fit, it is going to compromise performance to some extent...heck even going away from the stock offset will do that as well...I just don't think I will be putting the car in a position to notice the impact...what is important for me at this point is what has to be done to the car to make a non-staggered set up work like suspension, camber, rolling fenders, etc...I guess I will get to a point where it will not be worth it and go back to staggered but I owe it to myself to at least give it a shot and my wheel guy is into helping me while keeping my cost of trying at a minimum.
Not exactly sure what u mean by measruing the chassis...interested though if u wish to explain?
Old 04-06-14, 09:16 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Start by reading this. This is the first step in understanding how to effectively modify your suspension, regardless of what you drive or what you eventually intend to do with the car. AFAIK, no one here has done this yet, or if they have, they're not talking.
darinmg
Wheels, Tires & Brakes Forum
08-19-14 10:10 PM
Fortierr
04-13-12 02:56 AM
DDLexus
04-08-10 11:29 PM
I8ABMR
08-11-08 07:56 AM
dragon1992
04-02-08 12:36 AM
Quick Reply: Toyo Proxes T1 Sport tires
