What battery do you guys recommend?
Old 02-24-14, 06:17 PM
Mydogbella
Mydogbella's Avatar
Default What battery do you guys recommend?
I still have the original battery..what battery do you guys recommend?
Old 02-24-14, 07:24 PM
Raybean
Raybean's Avatar
optima red top.
Old 02-24-14, 07:32 PM
Mydogbella
Mydogbella's Avatar
Where is a good place to purchase a optima red top? And cost?
Old 02-24-14, 07:44 PM
flowrider
flowrider's Avatar
Received 1,826 Likes on 1,288 Posts
You may want to read these threads:
https://www.clublexus.com/forums/is-...uld-i-get.html
https://www.clublexus.com/forums/is-...ggestions.html
https://www.clublexus.com/forums/is-...w-battery.html
Found 'em with the Search Function.
Lou
Old 02-24-14, 07:46 PM
Mydogbella
Mydogbella's Avatar
Thanks Lou
Old 02-25-14, 06:44 PM
G9N
G9N's Avatar
I went with a red top. If you do, get the figs battery bar as the factory tie down is a bit loose with the red top installed. I wanted to get a GU1R but there's too many variables I wanted answered that couldn't be answered before I dropped $550 on a battery.
Old 07-22-14, 09:45 PM
hahahaf
hahahaf's Avatar
is the battery bar necessary for the red top?
I know a lot of people are running it
can anyone chime in?
Old 07-22-14, 09:53 PM
v8sten
v8sten's Avatar
screw the red top, i did a little research and this one will fit, its the same group #25 it just has the side posts too (which you wont use).
http://www.optimabatteries.com/en-us...nd-deep-cycle/
I personally have this battery in my car, the cables dont fit right but it works until i get the battery i stated above
Old 07-22-14, 10:04 PM
flowrider
flowrider's Avatar
The stock battery size is Group 24. And yes, the top bar on the battery holder secures the battery in its cradle. I, for one, wouldn't run without it.
Lou
Old 07-22-14, 10:07 PM
v8sten
v8sten's Avatar
Lou
the Red Top everybody puts in their cars is a Group 25
http://www.optimabatteries.com/en-us..._button=Search
Old 07-22-14, 10:19 PM
hahahaf
hahahaf's Avatar
is the battery bar necessary for the red top 25?
lol
Old 07-22-14, 10:21 PM
flowrider
flowrider's Avatar
That's fine. But, the correct size is group 24. Anybody can make things fit. I choose not to when it comes to an automotive battery.
Lou
Old 07-22-14, 10:50 PM
I8ABMR
I8ABMR's Avatar
used to run Optimas in my G35 but since Lexus oem batteries are covered under warranty if they die prematurely , and they ALWAYS seem to die early in AZ I havent paid for a battery in any of my 3 Lexus sedans. I have noticed with the 2 V8s I have had ( ISF and LS460) the batteries seem to die faster. I think its the added heat. The Optimas last a long time and they are lighter too
Old 07-22-14, 11:21 PM
revolut1on
revolut1on's Avatar
I am running one of these:
http://www.optimabatteries.com/en-us...cycle-battery/
Yes, the battery is smaller than the OEM Panasonic however it fits fine with the OEM battery tie with one of these:
http://i.ebayimg.com/00/s/MTA3OVgxNj...RF!~~60_35.JPG
The yellow Optima lifter tray fits snug into the OEM battery tray in the car and then lifts it to the correct height, and yes it should come with one of these as well. If not ask for one.
Old 07-23-14, 08:48 AM
hahahaf
hahahaf's Avatar
thanks
is that what everyones doing?
I think I'm with lou. id rather it fit then have to worry about trays
Quick Reply: What battery do you guys recommend?
