Lexus Certified ISF brake issues
Old 02-03-14, 07:53 PM
collinedw
collinedw's Avatar
Default Lexus Certified ISF brake issues
I just traded my 2008 USB ISF for a 2013 USB ISF. Came in today from Chicago and drove it and felt that the brakes were vibrating too much when pressed firmly. Vibration and noise occurs in response. This is a lexus certified preowned vehicle with 2435 miles on it. Has anyone had this issue or anything like this?
Thanks guys
Old 02-03-14, 08:23 PM
Looxs
Looxs's Avatar
I would check out what was replaced during the cpo process. With that mileage it wouldn't surprise me if the dealership deemed it unnecessary to change prior to being sold as a cpo vehicle.
Old 02-03-14, 08:36 PM
revolut1on
revolut1on's Avatar
Sounds like warped rotors. Either due to extreme braking conditions or brakes were sprayed with water whilst they were still too hot.
I would get them to replace the rotors and pads. It is not recommended to machine drilled rotors.
Old 02-04-14, 03:36 AM
Vervish
Vervish's Avatar
I would try re-bedding the brake pads. Sometimes deposits on the pad itself can cause a slight vibration.
Instructions here: http://www.zeckhausen.com/bedding_in_brakes.htm
Old 02-04-14, 08:10 AM
rmillsISF
rmillsISF's Avatar
I'd take it back to the dealer and make them fix it since it was CPO and you just got it. They should honor that.
Old 02-04-14, 08:48 AM
flowrider
flowrider's Avatar
Received 1,943 Likes on 1,369 Posts
Thanks guys
You may be interested in posts #5 and #6 in this thread:
https://www.clublexus.com/forums/is-...d-braking.html
Lou
Old 02-04-14, 02:36 PM
revolut1on
revolut1on's Avatar
Lou
Learn something new each day Now I know it's BS when my mechanic says it's warped.
One of my previous rides had shaking upon braking at speed and had it machined twice. Should have tried to bed them in then,
Old 02-04-14, 03:22 PM
Mydogbella
Mydogbella's Avatar
What does bed them in mean?
Old 02-04-14, 03:31 PM
shahir18
shahir18's Avatar
http://www.tirerack.com/brakes/tech/....jsp?techid=85
http://ebcbrakes.com/articles/how-to...ban-driving-2/
https://www.essexparts.com/learning-...rs/post/Bed-in
Basically... "breaking your brake pads in"
Old 02-04-14, 03:42 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,080 Likes on 2,472 Posts
Knowledge is power.
Old 02-18-14, 08:37 PM
collinedw
collinedw's Avatar
Lexus replaced the front rotors and pads bc they were warped and had hairline cracks in them. Thank god it was certified. Lexus took care of me but it should have never happened in the first place.
Old 02-18-14, 10:20 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
According to the factory service manual, cracks are acceptable unless they are longer than 30mm. Unless someone didn't torque the lugs properly, the rotors were not warped, they were not properly bedded and they had uneven pad transfer. This picture shows cracking beyond acceptable limits:
This picture shows a cracked but still perfectly serviceable rotor:
Old 02-19-14, 09:37 AM
scamsel
scamsel's Avatar
the last sentence in that link leaves you hanging, as I don't see any procedures!
"The recommended procedures below should provide you with the information you need to select the bed-in procedure appropriate for your application."
also, does one still follow a bed in procedure when just replacing pads?
Old 02-19-14, 10:00 AM
flowrider
flowrider's Avatar
In a word - YES
Lou
Old 02-19-14, 10:53 AM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
In a word - YES
Lou
If you are replacing the pads with the same manufacturer and the same model, no, you don't need to bed them the same as you would if you are changing manufacturer and compound.
Quick Reply: Lexus Certified ISF brake issues
