Raybestos rotors fitment...problem?
Old 09-23-13, 06:03 PM
BGG
BGG's Avatar
Default Raybestos rotors fitment...problem?
Hey guys, I ordered some reybestos rotors from amazon and upon installation I've noticed the inside portion of the rotor rubbing the inside portion of the caliper. Has anyone ran into this issue before? Thinks causing the two to grind and make an awful awful sound. Thanks for the help
Last edited by caymandive; 10-03-13 at 09:30 AM. Reason: corrected spelling in title
Old 09-23-13, 06:23 PM
flowrider
flowrider's Avatar
Received 1,828 Likes on 1,290 Posts
Here's a Blog from one of our site sponsor's where he installed Raybestos Rotors. He had no such issues.
http://figsengineering.blogspot.com/...akes-with.html
Lou
Old 09-23-13, 06:32 PM
caymandive
11 Second Club
caymandive's Avatar
I run these rotors as well with zero fitment or performance issues. Double check your installation.
Old 09-23-13, 07:15 PM
BGG
BGG's Avatar
I've double and quadruple checked everything and can't seem to find anything other than the rotor is too thick. Does the fact that my calipers are powdercoated have an effect on the situation?
Old 09-24-13, 03:40 PM
kteng7
kteng7's Avatar
^^ did you figure out what was wrong? i'm about to install mine in a few weeks.
Old 09-24-13, 07:31 PM
IronNam
IronNam's Avatar
Did you make sure it's the exact and correct part number?
Old 09-25-13, 08:09 AM
PatrickISF
PatrickISF's Avatar
Did you use a wire brush around the hub to make sure there was no debris left over from the previous rotors? It's possible that there is some dirt/rust that is keeping the rotor from sitting flush against the hub.
Old 10-02-13, 03:26 PM
Biggu
Biggu's Avatar
This, I have those rotors on mine with no issues and my calipers are powercoated as well.
Old 10-03-13, 08:10 AM
SoCal_450h
SoCal_450h's Avatar
I believe BGG found the problem...He forgot to install Dust pans
Old 10-03-13, 12:05 PM
kteng7
kteng7's Avatar
^^ thanks! I'm going to install mine tomorrow.
Old 10-03-13, 01:56 PM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Correct
Yes the OEM "Dust Shields" create a spacer like affect.. Without them the Caliper will hit the rotor as shown in the photo..
~ Joe Z
sakon3
17
06-11-20 02:17 PM
khizr23
05-08-19 12:02 AM
jorgie523
Suspension and Brakes
09-03-15 02:24 PM
HarrierRX300
01-27-13 10:48 PM
Stage3
Wheels, Tires & Brakes Forum
05-27-08 07:46 AM
Quick Reply: Raybestos rotors fitment...problem?
