08 w/20" rims - couple questions
Old 09-20-13, 11:48 PM
dannyk8232
dannyk8232's Avatar
Default 08 w/20" rims - couple questions
Picked up my 2008 yesterday. It has 20" InCurve IC-S5's, which look amazing. I was curious about a couple things...
Any ideas how much this will affect the speedometer and tach? I have a speedo app for my phone, but just curious.
There is a slight rub at very low speed when I turn into driveways. How concerned should I be about potential damage to the car? It's a little concerning, and I am wondering if it will be fine, or if I should swap for stock rims/tires.
Thanks in advance for any input!
Attached Thumbnails 08 w/20" rims - couple questions-small.jpg
Old 09-21-13, 04:28 AM
kauaian
kauaian's Avatar
Most likely that rubbing is the tire on the fender liner. However, I would figure out exactly what the tires are rubbing on to avoid potential damage. Are your fenders rolled or shaved?
Nice purchase!
Old 09-21-13, 08:24 AM
ROK
ROK's Avatar
put it simply, you bought wheels that don't fit.
unfortunately, with the isf, the only way to do it right is to get custom spec wheels (e.g. HRE, Forgeline, work, fikse, formula43, etc)
Old 09-21-13, 10:19 AM
dannyk8232
dannyk8232's Avatar
Thanks you guys...
I bought it Thursday and it already had these wheels...
How can I tell whether the fenders are rolled or shaved? Should I just jack up the front tires and poke my head around for wear?
Again, thank you very much for your input. I really would like to be sure there won't be significant damage from these in the long run.
Dan
shyguyF
shyguyF's Avatar
Look like your F have already lowered in the front, that's why it get slightly rubbed when you turn.What is your tires specs now ? So let's talk about speedo.
The wheels look very nice with the F color, don' t put the stock wheel back.
Old 09-21-13, 10:33 AM
yjk1975
yjk1975's Avatar
Your fine. It will not damage anything. Look on your tire and see if there is any rubbing marks. What is your tire sizes.
Old 09-21-13, 10:36 AM
dannyk8232
dannyk8232's Avatar
Front 245/35/20
Rear 285/30/20
I love the way they look, and I can't see any wear on the fender/wheel wells or the tires themselves.
So it looks lowered in the front to you?
Thank you!
Old 09-21-13, 11:09 AM
flowrider
flowrider's Avatar
Received 1,831 Likes on 1,293 Posts
^^^^It looks lowered because the wheel to fender gap is .5" smaller than stock. Your Tire sizes give the wheel/tire assembly an OD that is 1" over stock dimensions.
Lou
Old 09-21-13, 11:24 AM
yjk1975
yjk1975's Avatar
Lou
I think it looks lowered because of the tires. Next time you change out tires. It should be 245/30/20 and 285/25/20.
Check your springs and struts. See if aftermarket.
Old 09-21-13, 12:12 PM
dannyk8232
dannyk8232's Avatar
I will verify, but I am almost certain the springs/struts are stock.
Do you think the change in tire size may alleviate the rubbing sound altogether?
Old 09-21-13, 12:13 PM
yjk1975
yjk1975's Avatar
I would think yes.
Old 09-21-13, 12:50 PM
shyguyF
shyguyF's Avatar
both the font and rear tires are about 17-18mm taller than the oem tires so the speedo error is -2.5%, you should be fine due to under 3%.
Old 09-21-13, 08:23 PM
dannyk8232
dannyk8232's Avatar
Thank you again for all your advice and input. It is greatly appreciated.
I went to a wedding about an hour from my house today, so I got to spend a lot of time in the car for the first time. The rubbing or friction noise I hear and maybe feel is coming from the rears, and maybe not at all from the front tires. It seems to happen when the wheels are turned at low speeds and there is a bumpy patch, or an elevation change like a driveway.
Also I think I hear the same sound when the car bounces on an uneven patch of highway. Again, I believe it is from the rears.
It makes sense to me that the difference in tire size is eliminating ground clearance, but I am not sure why turning at low speeds would be related to the same rear tire issue. It even happens when I back out of my driveway and turn my wheels in reverse at 2 or 3 mph. My driveway isnt a significant change in grade/slope at all, and I think the noise occurs even after clearing the driveway and I'm turning in reverse while on the street just before completely stopping and shifting into drive/1st.
Old 09-21-13, 10:27 PM
flowrider
flowrider's Avatar
^^^^Because your tire/wheel combo is 1" larger in OD, you don't have less ground clearance, you actually should have more. But, your wheels wells were not designed for a wheel/tire combo larger in diameter than stock. And, for the record, I am not a proponent of what you have done
Lou
Old 09-21-13, 11:14 PM
dannyk8232
dannyk8232's Avatar
Lou
Thanks, Lou.
Just trying to gather information from experts on the subject. Bought the car Thursday, and came with this setup. Wasn't a choice, and hopefully I can identify a valid solution.
Dan
Quick Reply: 08 w/20" rims - couple questions
