California Smog Check Official thread
Old 03-13-17, 10:54 PM
  #106
sectorz33
sectorz33's Avatar
Wait a minute!.. you can pass smog check with I/h/E?! All it has to do is not have the CEL. That's blastfumy.. I want to know about this shop because I'm about to throw money at him.
Old 04-24-17, 06:24 PM
  #107
Manh3
Manh3's Avatar
has as anyone passed smog with an rr racing tune with I/H/E or gutted cats. Thanks
Old 04-24-17, 06:53 PM
  #108
seyelabrev
seyelabrev's Avatar
I just passed mine in San Jose.
Car has Borla & RR Racing Bazooka tips.
Old 04-24-17, 08:06 PM
  #109
Manh3
Manh3's Avatar
Seems like secondary cat removal doesn't affect the cars ability to pass smog but the primary cat removal, gut or header route does and this may lead to failing smog.
Old 05-01-17, 10:14 PM
  #110
JohnMorgan
JohnMorgan's Avatar
Gut or header route does if you're throwing the CEL, otherwise if the guy doesn't know what he's looking at (visual inspection) and their scanner checks out okay (running an O2 emulator if you're catless) then you pass. That's at least what someone at a smog station told me very recently.
Old 05-01-17, 10:21 PM
  #111
2010ISF
2010ISF's Avatar
Gutting the headers would probably be the everyone's best bet because if you get an O2 sim and put the stock cat back on for smog checks I feel like you should pass easily
Old 05-27-17, 10:16 AM
  #112
kzlflash
kzlflash's Avatar
Can someone PM me a shop in the 626 where they passed with I/H/E?
Thanks!
Old 05-27-17, 03:10 PM
  #113
empathy
empathy's Avatar
this is the route i went down. i considered headers, but cost of headers plus paying to swap back to stock and back to aftermarket headers every 2 years is a costly venture.
Old 05-28-17, 11:01 PM
  #114
jspecvtec
jspecvtec's Avatar
I don't think anyone that goes headers ever swaps back for smog 😂
Old 06-22-17, 08:53 AM
  #115
sucabstunn
sucabstunn's Avatar
With aftermarket headers removing the primary cats, you hope to get lucky and that the Smog tech does not do thorough visual check.
Old 06-22-17, 03:55 PM
  #116
Dv8tion388
Dv8tion388's Avatar
The key here without cats is A) not having a check engine light w/o2 'Ready" and/or B) having a visual friendly tech.
The PPE o2 conditioner feeds the o2 sensors good false data and therefore they will 'Ready' state. If the car was tuned with a flash and the o2's disabled then you wouldnt get a light either, but the SMOG computer would see the o2 sensors as in a 'Not Ready' state and trigger an auto fail.
I think, that if you guys with IHE had to smog, swap in the midpipe with the two factory cats and you should be cool with a visual and technical. The reason being is the cats in the mid pipe would be visual to a mirror check and the header cats are hardly seen to begin with. The electronic o2 conditioner will take care of the o2 sensors, I wouldnt trust the mechanical o2 anti foulers. Fact is if you own PPE headers they include the o2 conditioner as a solder in part to the ecu wiring.
Its been a while but sikky headers electronic o2 unit was a simulator instead of conditioner, similar to turning off the o2's from reading. The main trick here is that the o2 sensors need to be tricked into 'Ready' when the state computer reads them from the OBD2 port.
~Dv8
Old 06-22-17, 05:32 PM
  #117
virulosity
virulosity's Avatar
This is interesting info. I am heavily considering doing the novel headers and they have mechanical o2 conditioners. Are you saying that I should also get the PPE conditioners to run on top of that? Does RR racing have a tune that leaves the o2 lines open so that they can display ready?
Old 06-23-17, 10:50 AM
  #118
Dv8tion388
Dv8tion388's Avatar
Well, see if the mechanical antifoulers/simulators work for you. If not you gotta make a few phone calls. Will Novel headers fit the stock mid pipes? Just be aware you dont want any of the o2s to be turned 'OFF' in the tune when going to test.
~Dv8
Old 06-24-17, 02:26 PM
  #119
Rossi
Rossi's Avatar
Originally Posted by idoke1
I recently smogged my ISF with gutted cats and rr-racing tune in CA. It pass smog through the obd.
Are you using PPE conditioners, SIKKY simulators or did you select your tune to eliminate the O2 cel?
Old 06-24-17, 02:44 PM
  #120
Rossi
Rossi's Avatar
So selecting the option to eliminate the O2 cel with RRR tune would automatically fail the obd test, is that for sure?
if I am understanding this correctly, with any headers (PPE, SIKKY, NOVEL) the key is to use conditioners to pass the OBD test, I noticed RR Racing sells conditioners on their website, any difference between those and PPE ones? In the Sikky V2 installation video, James used conditioner so I think Sikky is now also going with conditioners not simulators.
Quick Reply: California Smog Check Official thread
