Will these wheels fit my ISF?
I'm thinking about getting Work varianza t1s wheels in 19x9.5 +20 and 19x11 +18. Will these specs clear my brembos and how aggressive would they be?
As far as calipers clearance goes, it doesn't determine by offsets but rather by the type of dish. JDM wheels usually have 3 different types of the faces with various dept to fit various type of brakes. More dept equal larger brakes and less lips
Front will fit with natural camber and 245 or less tires. Just for for information, I'm on 11.5 +40 which is same poke as 11 +34. I'm on 285 tires and have to run -3.8 camber with shaved fenders. Your rear wheel will stick out another 16mm which isn't going to work.
https://www.clublexus.com/forums/is-...isf-build.html
I agree with CalitriSC...as great as the T1S are, the offsets in the rear are not very kind to the F's rears. +20 in the front seems a bit low as well for the front, but there's a little more room up front than in the rear wheel wells. Are you planning to do anything to the fenders (rolling/cutting/pulling) to make these wheels work on your F? I'm not a fan of spacers, but if you really want those wheels, then that's probably your only choice, unless you run a cambered rear.
Great looking F there, MK4Sup_isF!
Thanks for the compliment bnizzle87
I've come to learn that very few people run wheels that fit. To me, a wheel that fits means no rubbing at full lock, full compression even when lowered sensibly with near stock alignment specs. Close to square tire profile (none of that stretched bs).
Your wheels here don't fit in my books.
BC Forged LE10 Wheels
Wondering if anyone could provide pictures and/or assistance and insight of the wheel setup I am looking to get:
Trying for below setup:
https://www.bcforged-na.com/modular/le10/ - LE10
19x9.5 +20 LE10 // standard mount - 48mm lip (Front) 245/35/19
19x11.0 +32 LE10 // standard mount - 55mm lip (Rear) 285/30/19
Also I plan to install SPC rear camber link arms + fender roll/shave + add more aggressive camber. How much camber do you guys think I would need to fit the wheels?
Very aggressive. Your going to have some problems getting them to fit, and will really need to pull the fenders. It’ll ruin the car, in my opinion.
thats what the rep at BC specd it out to be. Was planning on rolling/shaving fenders and ive see people do super aggressive just not as much but figured id ask the community here. Whats the camber probably gonna have to be?
